Visualize 2D Intrinsic Curvature of Spacetime (1s+1t) in 3D
In summary, 2D intrinsic curvature of spacetime (1s+1t) can be visualized in 3D through the use of mathematical models such as the Ricci tensor and the Riemann curvature tensor. These models allow us to understand the intrinsic curvature of spacetime and how it affects the motion of objects in the universe. By visualizing this curvature, we can gain a deeper understanding of the fundamental principles of general relativity and the structure of our universe. This visualization can also help us make predictions about the behavior of matter and energy in the presence of strong gravitational fields, such as those around black holes. Ultimately, visualizing 2D intrinsic curvature of spacetime in 3D allows us to better comprehend the
Martian2020
49
TL;DR Summary
I want to see correct visualization of curvature of spacetime (1d space+time) in 3d for spherical object of uniform density. Kind of Minkowski diagram.
Via web search found https://www.physicsforums.com/threads/what-dimension-does-space-time-curve-in.852103/
Read it and watched two videos mentioned:
I understand we cannot perceive 5D ;-), so extrinsic visualization of maximum of 2D intrinsic curvature is possible. So time+1d space is all we can see, and it is fine for sphere due to symmetry. I know not all intrinsic can be seen as extrinsic (is my language correct here?), however I understand spacetime curvature resulting from spherical mass can be correctly embedded, right?
In linked videos general idea of object going "straight"/geodesic line in spacetime is clear. However, I would like to find/see more informative visualization of spacetime curvature of spherical body with uniform density where it is clearly seen:
1) change from "gravitational force formula" outside a sphere to "falling" inside.
2) going though center and "raising" to opposite side of the sphere; extending it to several cycles
3) like on Minkowski diagrams with c*t axis being able to visualize "steepness" of curvature for escape velosity > speed of light
I was not able to find one via web search. Best I found was thread here mentioned above.
Visualization readily available is very good, any help with making one is appreciated too!
As a side note, the below visualizations cannot obviously show full spacetime (not 5D), but maybe they are not only useful tools and analogies but also correct visualizations of something?
P.S. I am not sure it is "basic", I am new here.
I think you are looking for something like this:
On the global scale spacetime is intrinsically curved (as shown below). It cannot be rolled out like the cone in the video above, which approximates just a small radial range:
The red path is the geodesic world-line of a free falling object, that oscillates through a tunnel through a spherical mass. Note that the geodesic always deviates towards the "more stretched" proper time, or towards greater gravitational time dilation. Gravitational time dilation has an extreme point at the center of the mass (gradient is zero), so there is no gravity there (but the maximal gravitational time dilation).
There is an interactive Flash version of that here (note that Flash is blocked by default by modern browsers):
http://www.adamtoons.de/physics/relativity.html
See also:
http://www.relativitet.se/Webtheses/tes.pdf
And other papers by Jonsson:
http://www.relativitet.se/articles.htmlBut note that this is not the usual space-coordiantetime diagram (Minkowski), but a space-propertime diagram as used in this book:
https://archive.org/details/L.EpsteinRelativityVisualizedelemTxt1994Insight/mode/2up
Howerver, in the papers by Jonsson linked above, you will find similar embeddings for Minkowski diagrams.
See here:
https://www.physicsforums.com/threa...-visualization-of-gravity.726837/post-4597121
Martian2020 said:
See here:
https://www.physicsforums.com/threa...curvature-more-accurately.753672/post-4747390
Likes Drakkith and Martian2020
Thank you!
It would take some time to go though resources you mentioned. In http://www.relativitet.se/Webtheses/tes.pdf I saw visualization like you included on page 9.
If you have a minute, could you help me clarify:
1) per quotation above, you mean "deviate" in our 3D space of cause (as geodesic is "straight")? Still it looks like you said only on going into sphere, on way back it does not look so...
2) If I make time scale more "dense" (fit more 8 minutes), looks to me I will be able to see several oscillations on one side w/out seeing through transparency. Is it correct way to do?
3) I could not quickly find visualization for space-coordianate time. Is it much different?
4) How can I see escape velocity on your visualization? Or is it possible only on space-coordianate time one?
I once saw a "coffee table" style picture book by Wheeler(?) that explained Einstein's equation visually, but I can't find it now.
Likes Keith_McClary
robphy said:
A Journey into Gravity and Spacetime (Scientific American Library
That looks like it!
Here are more papers:
The first video you posted "How Gravity Makes Things Fall", around 3:30 shows what happens on the way up. You can approximate any small radial range of the curved surface in my post as such a cone section.
The embedding-method has a free parameter, that determines how tight you roll the space time diagram. This will also affect the shape of the bulge. You cannot just change one axis scale on the same shape to describe the same situation.
Try this:
http://www.relativitet.se/Webarticles/2005AJP-Jonsson73p248.pdf
http://www.relativitet.se/Webarticles/2001GRG-Jonsson33p1207.pdf
Ths space-propertime embedding is described here in chapter 6:
http://www.relativitet.se/Webtheses/lic.pdf
I'm not sure if you can directly see it in either of them. The geodesic can get quite complex on these surfaces, so it's not obvious what initial direction (in space-time) you need to escape.
Likes Martian2020
http://www.sciencechatforum.com/viewtopic.php?f=2&t=24943
"In his book "Relativity Visualized", Lewis Carroll Epstein introduced a kind of spacetime diagram called a Space-Proper-time diagram. It has a few issues and is hence not often used in the literature, but for a quick grasp of special relativity theory, there is none better."
These diagrams could be significantly different from "usual" ones. I want to understand them, in the meanwhile I also wait maybe my question maybe visualized in "square" coordinates.
I wrote previous response not seeing these answers (not updated page in browser?). But I decided not to delete as it contains interesting link to discussion of Epstein diagrams. I'm going to study your links further now. Thank you.
A.T. said:
You link lot of stuff of Rickard Jonsson. Could you explain why on link 1 to explain gravity, shape have larger radius closer to center, but on link 2 to explain time dilation shape have smaller radius closer to center?
http://www.relativitet.se/spacetime1.html
"Some properties of the full theory will be lost due to the trick, but many of the truly important features will remain."
http://www.relativitet.se/spacetime2.html
"The technique used here gives images that requires a bit more knowledge to interprete correctly than those of spacetime1. On the other hand, when interpreted correctly, all the features of the true spacetime of a line will be incorporated."
This seems contradictory to myself...re-visited it twice.
Maybe as noted in the accompanying text 2nd is more correct... But how then see objects fall on 2nd shape?
It's two different types of space-coordinate time embedding, described in the two papers I linked.
The nice thing about the space-propertime embedding (3rd link, chapter 6) is that you can show both aspects in a single diagram. That's because space-propertime has an Euclidean metric, not the pseudo-Euclidean one.
I skimmed though chapter 6 (The Epstein-Berg way), looking at visualizations. I did not find one on which both fall and dilation was displayed. It could have been discussed... And also for Fig 6.3 "points does not correspond to events" (could not copy correctly from pdf, my wording). Not easy to understand that way...
See the diagram in post #2, and make sure you understand space-propertime diagrams:
One simple to way to visualize this, is to see everything advancing in space-propertime at the same rate, because the path-length here is the coordiante time.
The time dilation is the ratio of the displacement along the propertime axis and the path-length (coordinate time). This includes both: kinetic time dilation (trough projection onto the propertime axis) and gravitational time dilation (trough stretching of the propertime dimension -> more path-length (coordinate time) for the same propertime difference)
You can download the full book where space-propertime diagrams are introduced here.
https://archive.org/download/L.Epst...isualized [elem txt] (1994, Insight)_text.pdf
Yes, if you are dealing with two objects, the crossing of their paths in space-propertime is not a meeting. They meet if they are at the same spatial-coordiante after the same path-length (coordinate time). Their offset along the propertime axis is then the differential aging.
Martian2020 said:
Summary:: I want to see correct visualization of curvature of spacetime (1d space+time) in 3d for spherical object of uniform density. Kind of Minkowski diagram.
Imagine throwing a ball to a person 5 feet away. The ball rises 4 feet and the total flight time is 1 second.
Viewed in space, the ball travels in a parabola, rising 4 feet and traveling 5 feet horizontally.
But viewed in spacetime you need to add in a time axis and the distance between the start and end points is 1 second. You need to convert 1 second into a distance - it is 186,000 miles. Remember that the speed of light, c, is the conversion factor between distance and time: 1 second = 186,000 miles.
So, you have a "box" which is 5 feet wide, 4 feet high and 186,000 miles long.
The ball travels from the front, lower left corner of the box to the rear, lower right corner of the box; and rises 4 feet during its journey. As you can see its path is virtually straight.
You can get a feeling for how much Earth bends space(time) - by about 4 feet in 186,000 miles.
That is why I asked for sphere, not Earth specifically. I did not want to draw such long boxes ;-)
I've read time dilation in the center of Earth is some 0.000...%
Related to Visualize 2D Intrinsic Curvature of Spacetime (1s+1t) in 3D
1. What is intrinsic curvature of spacetime?
Intrinsic curvature of spacetime refers to the curvature of the fabric of the universe itself, rather than the curvature caused by the presence of massive objects. It is a fundamental property of spacetime that is described by Einstein's theory of general relativity.
2. How is 2D intrinsic curvature visualized in 3D?
2D intrinsic curvature of spacetime can be visualized in 3D by using mathematical models and computer simulations. These models and simulations can represent the curvature of spacetime as a 3D surface, with different colors or textures representing different levels of curvature.
3. What is the significance of visualizing 2D intrinsic curvature of spacetime?
Visualizing 2D intrinsic curvature of spacetime allows us to better understand the structure of the universe and how it behaves. It also helps us to visualize the effects of massive objects on the curvature of spacetime and how this affects the motion of objects in the universe.
4. How does 2D intrinsic curvature of spacetime relate to the concept of gravity?
In Einstein's theory of general relativity, gravity is not seen as a force between massive objects, but rather as a result of the curvature of spacetime caused by the presence of these objects. Therefore, visualizing 2D intrinsic curvature of spacetime can help us understand the nature of gravity and how it affects the motion of objects in the universe.
5. Are there any practical applications of visualizing 2D intrinsic curvature of spacetime?
While the visualization of 2D intrinsic curvature of spacetime is primarily used for theoretical and educational purposes, it can also have practical applications. For example, it can be used to model the behavior of objects in extreme environments, such as near black holes, and to make predictions about the behavior of the universe on a larger scale.
9K
