Visualizing the charge distribution in COMSOL
In summary,to visualize charge distributions in COMSOL, like showing + or - charges on a surface or a bulk in postprocessing, one can make a surface plot of the space charge density (es.rhoq), or make a surface plot of the polarization of the dielectric material (es.polarity).
feynman1
435
29
How to visualize charge distributions in COMSOL, like showing + or - charges on a surface or a bulk in postprocessing?
Make a surface plot of the space charge density (es.rhoq).
Thanks. That's a continuous distribution. What if I want to show discrete +/- charges?
There are no such things as discrete charges in the equations being solved, only a charge density.
Right. So I assume there's no such feature of visualizing as point charges. Point charges look more intuitive than surface distributions.
  • Skeptical
Likes Motore
Is there a feature of showing induced bound charges?
I dint understand. Do you mean polarization of a dielectric?
Yes, showing bound charges of a dielectric, caused by polarization.
Is the purpose of this for your internal 'understanding' or is it for the purpose of presenting ideas to others? I could see that a graphic of +and - charges could be familiar for people who are not well informed on the topic but why, as you are clearly familiar, would you want to go for a dumbed-down presentation? Presenting charge density as areas with random + or - signs scattered around could actually end up in a mess of symbols - if you actually want a hint of the quantitative situation. Just try it yourself, putting signs on a diagram, by hand. Is the result satisfactory?
Kind of both. Would be nicer to show them in the simulation directly, without myself plotting them.
Yes - of course. But you can see the result for yourself with just one example. Perhaps, rather than spending effort on producing an inferior display system, you could work on a way to explain what the available charge distribution display shows. It's clearly so much more informative that I'm sure you could convince even the most reactionary audience.
Likes DrClaude
You can plot the polarization of the material.
To add to what @sophiecentaur said, it would be could for you to learn to interpret the results by looking only at the charge density or the polarization. Using + and - charges may be good for pedagogical purposes (I do use that when I teach), but you'll go farther by being able to lose those training wheels!
Remember also that the actual discrete charges are electrons and ions. Any accurate representation of the charges would include so many of them as to lead back to what you see using a surface plot...
Likes sophiecentaur
yes, one can plot polarization. nice to plot a finite number of +- charges to represent a surface distribution, if possible.
Related to Visualizing the charge distribution in COMSOL
1. How can I visualize the charge distribution in COMSOL?
To visualize the charge distribution in COMSOL, you can use the "Charge Density" plot type in the Results tab. This will show the distribution of electric charge in your simulation model.
2. Can I change the color scale for the charge distribution plot in COMSOL?
Yes, you can change the color scale for the charge distribution plot by right-clicking on the plot and selecting "Properties." In the Properties window, you can adjust the color scale under the "Color" tab.
3. How can I see the charge distribution at a specific point in my simulation model?
You can use the "Probe" tool in COMSOL to see the charge distribution at a specific point in your simulation model. Simply click on the Probe tool and then click on the point of interest in your model.
4. Is it possible to animate the charge distribution in COMSOL?
Yes, you can animate the charge distribution in COMSOL by using the "Time" plot type in the Results tab. This will show the change in charge distribution over time in your simulation.
5. Can I export the charge distribution plot from COMSOL for use in other programs?
Yes, you can export the charge distribution plot from COMSOL by right-clicking on the plot and selecting "Export." You can choose the desired file format and save the plot for use in other programs.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
