Visualizing the Paraboloidal Wave
In summary, the wavefronts are approximated by paraboloids when the amplitude is small, but the true wavefronts are spherical when the amplitude is large.
yucheng
232
57
Try plotting....
$$U(\vec{r}) \approx \frac{A_0}{z} exp(-jkz) \exp(-jk\frac{x^2 + y^2}{2z})$$
We can either plot the real part of the complex amplitude, or the wavefront.
However, how is wavefront meaningful for varying amplitude? In order to plot the paraboloid, we must vary ##z##, which varies the amplitude ##\frac{A_0}{z}##. Unless the amplitude is varies little, i.e. ##1/z## approximately constant within ##\Delta z = \lambda##?
In the book Fundamentals of Photonics, Saleh & Teich, the author mentions that the phase of the second exponential function serves to bend the planar wavefronts into paraboloidal surfaces i.e. ##frac{x^2 + y^2}{2z} = \text{const}##, however, shouldn't it be ##z + frac{x^2 + y^2}{2z} = \text{const}## when plotting surfaces of constant phase i.e. wavefronts?
The result should look like this.
Thanks in advance!
From the link, they are considering spherical waves where $$U(\vec r) = \frac{A_0}{r}e^{-jkr}.$$ The phase is ##kr##. The true wavefronts are all spherical. For large distances from ##r = 0##, small patches of the wavefronts can be approximated by paraboloid-shaped wavefronts. (For very large distances, the wavefronts can be approximated by plane wavefronts.)
Consider moving out along the ##z## axis to some point ##P## with coordinates ##(x, y, z) = (0, 0, z_0)##. The phase of the wave at that point will be ##kz_0##. We look for points in the vicinity of ##P## for which the wave has the same phase. We assume ##z_0## is large enough so that points in the vicinity of ##P## will have coordinates ##(x, y, z)## satisfying ##x \ll z## and ##y \ll z##. For these points, $$r = \sqrt{x^2 + y^2 + z^2} \approx z + \frac{x^2+y^2}{2z} .$$ The condition that the phase ##kr## at these points be the same as at ##P## is $$k\left[ z + \frac{x^2+y^2}{2z}\right ] = k z_0$$ From this show that points near ##P## on the wavefront passing through ##P## have coordinates ##(x, y, z)## which satisfy $$z-z_0 \approx -\frac{x^2+y^2}{2z_0} .$$ Describe the shape of the locus of points ##(x, y, z)## satisfying $$z-z_0 = -\frac{x^2+y^2}{2z_0} .$$
Likes yucheng
TSny said:
$$z-z_0 \approx -\frac{x^2+y^2}{2z_0}$$
I guess this is the key. But why would it be a valid approximation though? Let me try a quantitative argument...
Related to Visualizing the Paraboloidal Wave
1. What is a paraboloidal wave?
A paraboloidal wave is a type of electromagnetic wave that has a parabolic shape. It is generated by a point source located at the focus of the parabola and propagates outward in a circular pattern.
2. How is a paraboloidal wave visualized?
A paraboloidal wave can be visualized using various methods such as ray tracing, computer simulations, or physical models. In ray tracing, the path of the wave is traced using geometric optics principles. In computer simulations, mathematical equations are used to generate a visual representation of the wave. Physical models involve constructing a physical representation of the wave using materials such as mirrors and lenses.
3. What are the applications of visualizing paraboloidal waves?
Visualizing paraboloidal waves has various applications in optics, astronomy, and wireless communications. It is used in designing and analyzing parabolic reflectors, satellite communication systems, and telescope mirrors.
4. How does visualizing paraboloidal waves help in understanding their properties?
Visualizing paraboloidal waves allows us to see the behavior and characteristics of the wave, such as its focal point, direction of propagation, and intensity. It also helps in understanding the effects of different parameters, such as the wavelength and focal length, on the wave.
5. Can paraboloidal waves be visualized in real life?
Yes, paraboloidal waves can be visualized in real life using physical models. For example, parabolic reflectors, such as those used in satellite dishes, can be seen as a physical representation of a paraboloidal wave. Additionally, computer simulations and ray tracing can also provide a realistic visualization of paraboloidal waves.
  • Optics
