Voltage across Capacitors in Parallel
In summary, the potential difference (voltage) across both capacitors is 2V. This is found by using the formula Qtotal = V(C1 + C2) and knowing that the charge and voltage must be the same for both capacitors when connected.
rocketgirl93
A 10μF capacitor is charged to 5V and then isolated. It is then connected across a second uncharged capacitor of capacitance 15μF. The potential difference, in V, across both capacitors is A) 0.2 B) 0.5 C) 2 D) 3
C= Q/V Ct=C1+C2
Finding the charge of the first capacitor and trying to use this to find charge of the other to find voltage. Find the energy stored in the first capacitor and assuming this is the charge available to the second capacitor. Various other shifting about and substituting of equations. Nothing worked!
C= Q/V Ct=C1+C2
What shall remain constant when you connect both the capacitors? :wink:
The charge..? But you don't have the charge for the second capacitor, how do you find it?
Good!
Initially, the second capacitor doesn't have charge. Only first capacitor posses charge.
When you connect both, the charges will flow and come to a steady state. Till how long the charge should flow? What should be the condition so that charge should stop flowing between the capacitors?
The charge will flow until the other capacitor is charged up?
Yep.
So how much charge is there to begin with?
In the end the voltage across the 1st capacitor will have to be the same as the voltage across the 2nd capacitor.
So if we call this as yet unknown voltage V, can you give the formula of how much charge is on each capacitor?
Aaaaaah I think I just got it,
If the overall charge is the same, and the voltages across the two capacitors have to be the same, Qtotal = C1V + C2V = V(C1 +C2) so the answer is 2?
Yes. :approve:
Yay! Thank you so much for your help!
FAQ: Voltage across Capacitors in Parallel
What is the formula for calculating the total voltage across capacitors in parallel?
The formula for calculating the total voltage across capacitors in parallel is Vtotal = V1 + V2 + V3 + ..., where V1, V2, and V3 are the individual voltages across each capacitor.
2. How does the voltage across capacitors in parallel compare to the voltage across each individual capacitor?
The voltage across capacitors in parallel is the same as the voltage across each individual capacitor. This is because in a parallel circuit, each component has the same voltage drop across it.
3. What happens to the total voltage when capacitors in parallel have different capacitances?
The total voltage across capacitors in parallel is determined by the individual voltages across each capacitor, not their capacitances. Therefore, the total voltage will remain the same regardless of the different capacitances.
4. Can the total voltage across capacitors in parallel ever be greater than the individual voltages?
No, the total voltage across capacitors in parallel can never be greater than the individual voltages. This is because the voltage in a parallel circuit follows the principle of conservation of energy, where the total voltage supplied is equal to the sum of the individual voltages.
5. How does the voltage across capacitors in parallel affect the overall current in the circuit?
The voltage across capacitors in parallel does not affect the overall current in the circuit. The current in a parallel circuit is determined by the total voltage and the total resistance, not the individual voltages of the components.
