Voltage division of a 5v regulator output?
In summary, the conversation discusses a problem with using expensive batteries for noise-cancelling headphones and the idea of using a resistive voltage divider to regulate the voltage for the headphones. It is suggested to use batteries in parallel instead of series to increase the effective capacity and the risk of putting too much current through the headphones is addressed. The idea of using a Buck DC-DC converter is also mentioned as a more efficient solution. The conversation also mentions the possibility of using one larger battery instead of several smaller ones.
jack476
328
125
So here's my problem. I have a pair of noise-cancelling in-ear headphones, and they require a AAA battery. Batteries are expensive so I only use rechargeable ones, but those have a lower capacity (700 maH) and don't last long. I want to make it last longer by putting several of them together into a battery pack. However, that would need to be regulated down to the voltage of a single AAA battery, 1.5v, but I only have 5v regulators.
What I'm thinking of doing is putting a resistive voltage divider on the output of the 5v regulator that would take the voltage down to the 1.5v that the headphones are rated for. Would that work?
Could you not just put the batteries in parallel instead of series?
batteries in series increase the voltage,
batteries in parallel increase the effective capacity
Or so is my understanding :D
That actually makes a lot more sense. But wouldn't it risk putting more current through the headphones than they're designed to take?
Nope, the current drawn is determined by the resistance (aka 'load') of the headphone circuit.
It will be the same regardless of how many batteries you have in parallel.
The total current supplied will be shared by the batteries, so that means the individual batteries will last longer before needing recharging.
The parallel battery idea is a good one. Just make sure the batteries are matched well (charged the same, same age, etc.) before you parallel-connect them.
BTW, on your idea of doing a resistive voltage divider down from 5V, that will not extend the battery life. What you gain with the higher voltage is lost in wasted head in the resistor voltage divider. Instead, you would use a "Buck" DC-DC converter to convert the higher voltage down to 1.5V. Buck DC-DC converters can be around 90% efficient in many cases. :smile:
Why put several cells in parallel when one larger cell will do?
>3600mAh NiMh cells are available.
It's just all I've got on hand at the moment. I also just bought my textbooks and I don't want to spend any more money than I have to for a little while.
Related to Voltage division of a 5v regulator output?
1. What is the purpose of voltage division in a 5v regulator output?
Voltage division in a 5v regulator output is used to split the output voltage into smaller, more manageable voltages. This allows for different components in a circuit to receive the appropriate voltage level for their operation.
2. How does voltage division work in a 5v regulator output?
Voltage division works by using a series of resistors to create a voltage divider circuit. The resistors are connected in series, and the output voltage is taken from the middle point between the two resistors. This results in a lower voltage than the original 5v output.
3. What is the formula for calculating voltage division in a 5v regulator output?
The formula for calculating voltage division is Vout = Vin * (R2 / (R1 + R2)), where Vout is the output voltage, Vin is the input voltage (5v in this case), R1 is the resistance of the first resistor, and R2 is the resistance of the second resistor.
4. Can voltage division be used to increase the output voltage of a 5v regulator?
No, voltage division can only be used to decrease the output voltage. This is because the output voltage is always taken from the middle point between the two resistors, resulting in a voltage that is lower than the input voltage.
5. What are some common applications of voltage division in a 5v regulator output?
Some common applications of voltage division in a 5v regulator output include powering different components in a circuit that require different voltage levels, creating reference voltages for analog circuits, and reducing the voltage for sensors or other components that have a limited voltage range.
  • Electrical Engineering
9K
