Voltage inbetween two angled plates?
In summary, to find the potential at any point between the two angled plates, you can use the Laplace equation in cylindrical coordinates and solve it using the method of separation of variables.
Ayol
Potential between two angled plates?
I have a problem involving two angled plates
Diagram
http://imageshack.us/photo/my-images/841/paintzr.jpg/
L=10cm
d=1mm
[itex]\phi[/itex]= 1°
Where I'm supposed to find the potential at any point between the plates. I recognize that I'm supposed to use the Laplace equation in cylindrical coordinates and that V is independent of z, but I end up with an equation that looks like:
0=1/ρ * ∂/∂ρ * (ρ * ∂V/∂ρ) + 1/ρ^2 * ∂^2v/∂ [itex]\Phi[/itex] ^2 (I think)
and I have no idea what I'm supposed to do with it. If someone could clarify that it would be nice.
Thanks in advance.
The equation you have is correct. To solve it, you can separate the variables using the method of separation of variables. That is, assume that the solution has the form V(ρ,ϕ)=X(ρ)Y(ϕ). Substituting this form into the Laplace equation will yield two ordinary differential equations which can be solved separately. The general solution will be a linear combination of these two solutions.
FAQ: Voltage inbetween two angled plates?
1. What is the formula for calculating the voltage in between two angled plates?
The formula for calculating the voltage in between two angled plates is V = Ed, where V is the voltage, E is the electric field strength, and d is the distance between the plates.
2. How does the angle of the plates affect the voltage in between them?
The angle of the plates does not have a direct effect on the voltage in between them. However, it does affect the electric field strength, which in turn affects the voltage.
3. Can the voltage between two angled plates be negative?
Yes, the voltage between two angled plates can be negative. This occurs when the electric field points in the opposite direction of the voltage, resulting in a negative value.
4. What is the unit of measurement for voltage?
The unit of measurement for voltage is volts (V).
5. How does the distance between the plates affect the voltage?
The distance between the plates directly affects the voltage. As the distance increases, the voltage decreases and vice versa. This can be seen in the formula V = Ed, where d is the distance between the plates.
