Voltage Increase through Induction
In summary, the conversation discusses the need for calculating the number of windings required to increase voltage in a system from 12v to approximately 400v. The use of a transformer is suggested, but it is noted that transformers only work for AC and a DC-DC step-up converter would be needed for a DC system. The potential size and danger of the converter is mentioned and the person is asked about the purpose of the project.
mmaresco
I am new to the field and have stumbled across an issue. The current project I am working on is requiring me to calculate how many windings I need to increase voltage in a system from 12v to ~400v. The Initial winding will be fed from a 0 A.W.G. braided copper wire and the outgoing feed will, ideally, be a 8 A.W.G. braided copper wire. Is there a formula that can enable me to acquire this calculation.
Welcome to the PF.
If you are talking about AC, then the voltages ratio with the number of turns for each winding.
The system would run on DC.
A transformer sadly only works for AC since you need a time-varying magnetic field for electromagnetic induction.
For what you're asking, you need a DC-DC step-up converter.
Yeah, and from the sound of the size of wire and the high output voltage, this will be one BIG DC-DC converter.
@mmaresco -- since you say that you don't have experience with this, you are not going to be able to design and build such a converter. Not to mention that your 400V output voltage will make the whole setup quite dangerous. Why are you being asked to look into this? What is the application?
FAQ: Voltage Increase through Induction
What is voltage increase through induction?
Voltage increase through induction is a process in which a changing magnetic field induces an electric current in a conductor, resulting in an increase in voltage. This phenomenon is known as electromagnetic induction and is the basis for many electrical devices.
How does voltage increase through induction occur?
When a conductor, such as a wire, is placed in a changing magnetic field, the magnetic field lines will cut across the conductor, which creates a flow of electrons. This flow of electrons results in an increase in voltage, known as an induced voltage, across the ends of the conductor.
What factors affect the magnitude of voltage increase through induction?
The magnitude of voltage increase through induction depends on several factors, including the strength of the magnetic field, the speed of the change in the magnetic field, the orientation of the conductor in the field, and the length and thickness of the conductor.
Is voltage increase through induction a reversible process?
Yes, voltage increase through induction is a reversible process. If the magnetic field is removed or the conductor is moved out of the field, the induced voltage will decrease and eventually return to zero.
How is voltage increase through induction used in everyday devices?
Voltage increase through induction is used in a variety of everyday devices, including generators, transformers, and induction cooktops. It is also used in wireless charging technology, where a changing magnetic field is used to induce a current in a device to charge its battery.
