fourthindiana
- 162
- 25
I am reading a book titled Refrigeration and Air-Conditioning Technology, and I am now at a chapter in Refrigeration and Air-Conditioning Technology about Automatic Control Components and Applications. I am confused about a sentence in a section of this chapter regarding thermostats. The thermostat section of the book compares and contrasts motor winding thermostats and space temperature thermostats. Motor winding thermostats are thermostats on the compressors of air-conditioners.
Space temperature thermostats are thermostats for residential/commercial air-conditioning. The purpose of this thread is to ask about one sentence in this paragraph that I don't understand. I believe that the entire paragraph that contains this confusing sentence and the entire paragraph before the confusing sentence should be included for context.
I will boldface and color the confusing sentence green in the quote. Here is the quote and the confusing sentence I am asking about:
"Another difference between the two thermostats is the medium they sense. The motor-winding thermostat must be in close contact with the motor winding. It is fastened to the winding itself. The space temperature is mounted on a wall and responds to random air currents passing over it. Another important design concept is the current carrying characteristics of the various controls. In the space temperature application, the stopping or starting of a heating system, such as a gas or oil furnace, involves stopping or starting low-voltage (24 volt) components and line-voltage (115-volt or 230-volt) components. The gas or oil furnace normally has a low-voltage gas valve or relay and a line-voltage blower motor.
There is no firm rule for using one voltage or another in any specific application. However, the stopping and starting of a 3-hp compressor requires a larger switching mechanism than the one used to control a simple gas valve. A 3-hp compressor could operate with a running amperage of 18A and a starting amperage of 90 A, whereas a simple gas valve might draw only 0.5 A. If a bimetal were large enough to carry the current for a 3-hp compressor, the control would be so large that it would be slow to respond to temperature changes. This is one reason for using low-voltage controls to stop and start high-voltage components."
It sounds to me like in the sentence I colored green, the authors are talking about an analog thermostat with a bimetal to control the thermostat. Why would a large bimetal in a thermostat be slower to respond to temperature changes than a small bimetal in a thermostat? The bimetal is a piece of brass attached back to back with steel. I am aware of the fact that a longer bimetal will bend further than a shorter bimetal, but the degrees of bending would be the same. Let me make an example. In the example, the stationary part of the bimetal will be the reference line of an angle. I don't see why it would take longer for a, say, 10 inch long bimetal to bend from 180 degrees to 160 degrees than it would take a 5 inch long bimetal to bend from 180 degrees to 160 degrees.
If a bimetal were large enough to carry the current for a 3-hp compressor, how would the large size of the control cause the control to be slow to respond to temperature changes?
