Smooth
- 6
- 3
Hi,
I'm trying to figure out how the angle of incidence will affect the voltage output of a photodiode. The obvious answer that comes to my mind is that the voltage output should be proportional to the cos(α), where α is the angle of incidence of light. However, I couldn't find any formula/article that states this.
Is that true? If so, where can I read about it?
Also, an important thing is that I'm interested in the case when the photodiode is in space – so I can assume that there is no reflected light interfering with the readings. Cause I found some people with experimental data that sort of goes along with my assumption:
http://www.diva-portal.org/smash/get/diva2:858954/FULLTEXT02
https://www.researchgate.net/publication/260532829_Effect_of_Tilt_Angle_Orientation_on_Photovoltaic_Module_Performance
