Voltage Regulator w/ Zener Diodes
In summary, the problem involves calculating the output voltage, line regulation, and load regulation of a voltage regulator circuit consisting of zener diodes with certain test current, incremental resistance, and knee current values. The output voltage at nominal voltage and no load is calculated using the equations V_z=V_zo+r_z*I_z and I_z=(V+ - V_zo)/(R+r_z). The line regulation is found to be (+/-) 74 mV/V by considering the change in output voltage resulting from a +/- 1 volt change in V+ using the equation ΔV_o=ΔV+*(r_z/(R+2*r_z)) + ΔV+*(r_z/(R+2*r_z)). The
vermin
The diagram:
http://images.fr1ckfr4ck.fastmail.fm/probB.jpg
These zener diodes;
  • Have a test current of 5mA when 6.8V is applied (V_z=6.8V, I_z=5mA)
  • Have an incremental resistance (r_z) of 20 ohms
  • Knee current (I_zk) is 0.2mA
  • Calculate the output voltage of the voltage regulator, assuming no load (R_L = infinite) and V+ is at nominal value.
  • Calculate the line regulation of the voltage regulator, assuming no load.
  • Calculate load regulation of the voltage regulator.
see below
To get the output voltage at nominal voltage and no load, I first went to solve for V_zo using V_z=V_zo+r_z*I_z and the test current I_z=5mA. That told me V_zo = 6.7V. Then I solved for I_z using I_z=(V+ - V_zo)/(R+r_z). I decided to go ahead and find I_z for one diode, then solve for half of V_o later. I_z turned out to be, for one diode, I_z = (15 - 6.7)/(500+20) = 16mA. So then to solve for output voltage V_o, I used
(1/2)V_o=V_zo+r_z*I_z
I_z being not the test current but the one I just solved for. So;
(1/2)V_o=6.7+20(.016)
V_o=14.04 V
It makes sense to me that the voltage should be ~1V less under a 500 ohm resistor, so I think that's a good answer.
As for line regulation - I'm looking for the change in V_o resulting from the +/- 1 volt change in V+ (14 to 16 V).
If there were only one zener diode it would be as simple as ΔV_o=ΔV+*(r_z/(R+r_z))
But since there's two in series, I have to decide what to double and when.
Since that equation is asking what the change in V_o is when you consider the change contributed by the zener diode, I decided that the equation should be done twice and involve both diodes. It looks like voltage division to me, so if there's three resistors it should involve all three.
So, I changed r_z to 2*r_z:
Since ΔV+=2V, it all comes out to ΔV_o=2(20/(500+40))+2(20/(500+40))=8/54=0.148
expressed in mV/V --> 148 mV/V
and since it's a deviation they want I'd say the answer is (+/-) 74 mV/V.
Load Regulation:
Looking for the ratio of the difference in V_o vs. the difference in I_L, the current through the load.
A load resistance that draws a current of 1mA will cause the current through the zener diodes branch to decrease by 1mA. Normally if there's one diode that change would be;
ΔV_o=r_z*ΔI_z
But in this case there's two. Still, though - since the total current change will remain 1mA, it should be divided evenly between both diodes, and the end result stays the same. The load regulation should be proportional to r_z; -20 mV/mA
I have a sinking feeling I messed this all up. Any tips on where I went wrong or what I did right, would help. Thanks in advance.
There won't be anything like 16mA through that 0.5k resistor; that would need 8v across it, and the pair of zeners don't leave that resistor even 2v.
Why only one zener considered here?
Likes 1 person
ok. I guess I could answer that if I was seeing the big picture here, but I'm not. I thought there was one I_z to find that's true for both zeners but I guess not. I'm going back over a similar problem using one zener and see how to adapt it. meanwhile, any tips on a general approach would help, thanks.
Replace both zeners with an equivalent model consisting of a resistor, ideal diode, and voltage source (Initially assume that sufficient current will flow to cause zener action). Analyze the circuit: Use Kirchhoff's laws to determine the actual current and the output voltage.
Likes 1 person
Right that's just what I'm doing and where I'm getting stuck is this; I have replaced the two zener diodes each with voltage sources of voltage V_Zo=6.7v, and resistors r_z=20 ohms. Now, I could say the total current going into the node above, which should equal the current through R, would be I_z=(V-V_R)/(R+r_z)=(15-6.7)/(500+20)=16mA
but then if I just take that current and double it, one for each zener diode, I get 32mA, and that doesn't jive with the resistor R above because it would mean that V_R (voltage across that resistor) = (32mA)(500ohm)=16V.
So, what, then it means that the current is the same through two zener diodes as it is through one? Then V_R would = 8V, and V_o would = 7V. doesn't seem right either.
Big question for me is how to account for the current at the node above the two zener diodes, because I've only solved problems with one zener before and I don't know how to handle having two of them.
Ok. So. The only thing that's making sense to me right now for that current is using I_z=(V-Vzo*2)/(R+r_z*2), because that makes I_z = 2.96mA, which in turn means V_R = 1.48V. It seems to make sense that under no load the voltage drop V_o would be around 13.52V, at least intuitively.
Just call it "the voltage V_o". The label "voltage drop" isn't approprate here.
You could refer to the voltage across R as a voltage drop. Or ΔV_o as a voltage drop under load.
Likes 1 person
Thanks for the pointers on terminology but my burning question is if I'm finding the potential there at V_o correctly.
Does that seem correct, then? using I_z=(V-Vzo*2)/(R+r_z*2) for the current going into that node, and V_o being 13.52V?
That is correct.
Likes 1 person
FAQ: Voltage Regulator w/ Zener Diodes
What is a voltage regulator with Zener diodes?
A voltage regulator with Zener diodes is a type of electronic circuit that is used to maintain a constant output voltage, even when the input voltage varies. It is made up of Zener diodes, which are specially designed diodes that allow current to flow in the reverse direction when a certain voltage is reached, and other components such as resistors and capacitors.
How does a voltage regulator with Zener diodes work?
The Zener diodes in the voltage regulator act as a reference for the output voltage. When the input voltage increases, the Zener diodes start to conduct in the reverse direction, which creates a voltage drop across them. This voltage drop is then used to regulate the output voltage to a constant level.
What are the advantages of using a voltage regulator with Zener diodes?
One of the main advantages of using a voltage regulator with Zener diodes is that it can provide a stable output voltage, even when the input voltage fluctuates. This makes it useful in electronic circuits that require a constant voltage, such as in power supplies. Additionally, Zener diodes are relatively inexpensive and easy to use, making them a popular choice for voltage regulation.
What are some common applications of voltage regulators with Zener diodes?
Voltage regulators with Zener diodes are commonly used in electronic devices that require a constant voltage, such as computers, televisions, and mobile phones. They are also used in power supplies for electronic circuits, battery charging circuits, and in automotive electronics.
How do I choose the right voltage regulator with Zener diodes for my project?
The choice of voltage regulator with Zener diodes will depend on the specific requirements of your project, such as the input and output voltage levels and the amount of current needed. It is important to select a regulator with a suitable voltage rating and current handling capacity to ensure it can handle the power requirements of your circuit. It is also recommended to consult a datasheet for the specific regulator you are considering to ensure it meets your project's needs.
