Volume by parallel cross-section.
In summary, the base of a solid is bounded by the lines y=x^2 and y=4, and the volume is found by taking the integral of A(x) = (4-x^2)^2 from x=-2 to x=2. The volume element is represented by (4 - x2)(4 - x2)\Delta x, with the first factor being the distance between the two lines, the second factor being the vertical height, and the \Delta x factor being the thickness. The final answer is 512/15 and any calculation errors can be corrected by using the shell method.
Call my name
The questions: the base of a solid is the region bounded y=x^2 and y=4. Find the volume of the solid given that the cross sections perpendicular to the x-axis are squares.
The answer is 512/15.
I set A(x)= (2y)^2 = 4(x^2)^2=4x^4, and the answer is wrong when I integrate this from x = -2 to x = 2.
How can I solve this?
Please help me.
The typical volume element, [itex]\Delta V[/itex], has a volume of (4 - x2)(4 - x2)[itex]\Delta x[/itex]. The first factor of (4 - x2) is the distance between the line y = 4 and the curve y = x2. The second factor of (4 - x2) is the vertical height of the volume element (perpendicular to the x-y plane). The [itex]\Delta x[/itex] factor is the thickness of the volume element.
That's more confusing... can you explain it with integrals?
Maybe this picture will help you:
Thank you for the picture, but I do understand how it looks...
just don't know how it goes with the integrals...
so A(x) = (4-x2)2 ?
2[tex]\int[/tex](4-x2)2dx (x is 0~2)
Yes, since you have symmetry about x = 0.
But, I am not getting 512/15.
Then you have done something wrong.
[tex]\int_{x = -2}^2 (4 - x^2)^2 dx~=~2\int_{x = 0}^2 (4 - x^2)^2 dx~=~\frac{512}{15}[/tex]
Yes. made some calculation error
Mark44 said:
Did you find out where you went wrong?
Yes. Thank you. I have posted another question this time regarding shell method
FAQ: Volume by parallel cross-section.
What is volume by parallel cross-section?
Volume by parallel cross-section is a method of calculating the volume of an object by taking cross-sectional slices of the object and adding them together. This is often used for irregularly shaped objects or objects with varying cross-sectional areas.
How is volume by parallel cross-section different from other methods of calculating volume?
Unlike other methods, volume by parallel cross-section takes into account the varying cross-sectional areas of an object, making it more accurate for irregularly shaped objects.
What are some real-world applications of volume by parallel cross-section?
Volume by parallel cross-section is commonly used in fields such as architecture, engineering, and manufacturing to calculate the volume of irregularly shaped objects or structures.
How do you calculate volume by parallel cross-section?
To calculate volume by parallel cross-section, you first need to take measurements of the cross-sectional areas of the object at regular intervals. Then, you add these areas together and multiply by the distance between each cross-section to get the total volume.
What are the limitations of volume by parallel cross-section?
Volume by parallel cross-section may not be accurate for objects with complex internal structures or irregularly spaced cross-sections. Additionally, it may be difficult to obtain precise measurements for the cross-sectional areas, leading to potential errors in the calculation.
