Volume element in Spherical Coordinates
In summary, Descartes coordinates are named after Descartes, and they are usually called "Cartesian coordinates". The expression for the spherical volume element is not correct, and it is given by ##dV = \rho^2\sin{\phi}\,d\rho\,d\theta\,d\phi##. The "why" of the volume element arises from various less rigorous ways to see it. Volume elements in cartesian and spherical coords can be found using simple geometry.
LagrangeEuler
717
For me is not to easy to understand volume element ##dV## in different coordinates. In Deckart coordinates ##dV=dxdydz##. In spherical coordinates it is ##dV=r^2drd\theta d\varphi##. If we have sphere ##V=\frac{4}{3}r^3 \pi## why then
[tex]dV=4\pi r^2dr[/tex]
always?
The coordinates are named after Descartes and are usually called "Cartesian coordinates".
I don't think your expression for the spherical volume element is correct: It misses a factor ##\sin{\phi}##, so: ##dV = \rho^2\sin{\phi}\,d\rho\,d\theta\,d\phi##.
As to the "why": There are various less and more rigorous ways to see it. The rigorous answer is that the factor ##\rho^2\sin{\phi}## arises (up to a sign) as the determinant of the matrix ##\frac{\partial (x,y,z)}{\partial (\rho,\theta,\phi)}## that describes the changes-of-variables from Cartesian to spherical. This is discussed in multivariable calculus books such as Marsden and Tromba's Vector Calculus.
Likes vanhees71
Yes I forgot ##\sin \theta##.
Yes, look for "Jacobi determinant".
It's also very easy to understand when you remember that for three vectors ##\vec{a}##, ##\vec{b}##, and ##\vec{c}## the volume of the parallelipiped spanned by them is ##V=|\vec{a} \cdot (\vec{b} \times \vec{c})##. It's easy to understand when you remember the meaning of ##\vec{b} \times \vec{c}## and the fact that the volume of the parallelipiped is given by "area times height".
Now apply this to the given coordinates. They are defined by
$$\vec{x}=\vec{x}(r,\vartheta,\varphi)=\begin{pmatrix} r \sin \vartheta \cos \varphi \\ r \sin \vartheta \sin \varphi \\ r \cos \vartheta \end{pmatrix}.$$
Now look at an arbitrary point at the three "coordinate lines", i.e., the lines which are defined by varying one of the coordinates and leave the other constant. At the point defined by ##(r,\vartheta,\varphi)## you get three tangent vectors spanning a little box-like volume, and this you can use as the volume elements in volume integrals. So what you get is
$$\mathrm{d}^3 x = \mathrm{d} r \mathrm{d} \vartheta \mathrm{d} \varphi |(\partial_r \vec{x}) \cdot (\partial_{\vartheta} \vec{x} \times \partial_{\varphi} \vec{x})|.$$
It's a good exercise to do this calculation and prove that indeed
$$\mathrm{d}^3 x = \mathrm{d} r \mathrm{d} \vartheta \mathrm{d} \varphi r^2 \sin \vartheta.$$
Another way to see it is also to simply draw the coordinate lines and the little box spanned by it. Then you can read off the volume using simple geometry.
Likes Adesh
Are you leaking intuition, or do you have trouble to understand how to derive it?
Another way to derive these area elements is the use of exterior derivatives, which i'll give you a quick example with polar coords. Let ##x=r \cos \theta## and ##y = r \sin \theta##. An area element in cartesian coords is simply ##dxdy##(which *technically* is ##dx \wedge dy##) so, all we have to do is find out what "##dxdy##" is in polar coords! Thus, ##dx = \cos \theta dr - r \sin \theta d \theta \text{ and } dy = \sin \theta dr + r \cos \theta d \theta## From here we see that $$dx \wedge dy = \cos \theta \sin \theta dr \wedge dr +r \cos^2 \theta dr \wedge d \theta - r \sin^2 \theta d \theta \wedge dr -r^2 \sin \theta \cos \theta d \theta \wedge d \theta $$
A few things you may not know is that ##\wedge## is called a "wedge product", ##dx \wedge dy = -dy \wedge dx## (this is what is known as anti-symmetry!) and that ##d(anything) \wedge d(anything) = 0## (this follows from the above property, you may ponder why!). So, cleaning up our formula we see that...
$$dx \wedge dy = r \cos^2 \theta dr \wedge d \theta + r \sin^2 \theta dr \wedge d \theta = r dr \wedge d \theta (\cos^2 \theta + \sin^2 \theta) = r dr \wedge d \theta$$ or when you take the wedges out (since they are just a product...) you get $$dxdy = rdrd\theta$$ The same can be down for spherical coords to find the volume element!
Likes vanhees71
FAQ: Volume element in Spherical Coordinates
What is a volume element in spherical coordinates?
A volume element in spherical coordinates is a small volume in three-dimensional space that is defined by three parameters: radius (r), polar angle (θ), and azimuthal angle (φ). It is used to calculate the volume of a three-dimensional object or region in spherical coordinates.
How is the volume element in spherical coordinates calculated?
The volume element in spherical coordinates is calculated using the formula dV = r² sinθ dr dθ dφ, where r is the distance from the origin, θ is the polar angle, and φ is the azimuthal angle. This formula takes into account the changing size and shape of the volume element as it moves away from the origin.
What are the units of measurement for the volume element in spherical coordinates?
The units of measurement for the volume element in spherical coordinates depend on the units of measurement for the three parameters (r, θ, and φ). For example, if r is measured in meters, θ in radians, and φ in degrees, then the volume element will be measured in cubic meters (m³).
How is the volume of a three-dimensional object calculated using spherical coordinates?
The volume of a three-dimensional object in spherical coordinates is calculated by integrating the volume element (dV) over the entire region of interest. This means taking the triple integral of dV with respect to r, θ, and φ. The resulting value will be the volume of the object in the specified units of measurement.
What are some real-life applications of spherical coordinates and volume elements?
Spherical coordinates and volume elements have many real-life applications, such as in physics, engineering, and astronomy. They are used to calculate the volume of three-dimensional objects, such as spheres, cones, and cylinders. They are also used in the study of electromagnetic fields, fluid dynamics, and celestial bodies. Additionally, they are used in navigation and mapping, as well as in computer graphics and 3D modeling.
