Volume enclosed by rotating a curve segment
In summary, the volume enclosed by rotating the segment of the curve $y = \frac{1}{2}|x-1|$ between $x = 0$ and $x = 2$ about the $x$-axis is equal to $\frac{\pi}{3}$. This is found by calculating the volume of two cones with base radius $\frac{1}{2}$ and height $1$, which can be represented by the integral $\frac{\pi}{2}\int_0^1(1-x)^2\,dx=\frac{\pi}{6}$.
Guest2
193
The volume enclosed by rotating the segment of the curve $y = \frac{1}{2}|x-1|$ between $x = 0$ and $x = 2$ about the $x$-axis is equal to:
Is it this simple? Since $x \ge 0$ it's $\frac{\pi}{2} \int_0^2 (\sqrt{(x-1)^2})^2\, dx = \frac{\pi}{3}.$
No, it's not that simple, because you are going to have two different functions from the absolute value. For $\displaystyle \begin{align*} 0 \leq x < 1 \end{align*}$ we have $\displaystyle \begin{align*} \frac{1}{2} \, \left| x - 1 \right| = -\frac{1}{2} \, \left( x - 1 \right) \end{align*}$ while for $\displaystyle \begin{align*} 1 \leq x \leq 2 \end{align*}$ we have $\displaystyle \begin{align*} \frac{1}{2} \,\left| x - 1 \right| = \frac{1}{2} \, \left( x - 1 \right) \end{align*}$.
Thank you. So it's [tex]\frac{\pi}{4}\int_0^1 (1-x)^2\,{dx}+\frac{\pi}{4}\int_1^2 (x-1)^2\,dx = \frac{\pi}{6}[/tex]?
Is it by coincidence that I get the same answer from what I was doing earlier as well?
I made a mistake so the answer was off, but now I get $\displaystyle \frac{\pi}{4} \int_0^2 (\sqrt{(x-1)^2})^2\, dx = \frac{\pi}{6}.$
We know, by looking at the graph, and using the formula for the volume of a right circular cone, that we will have:
\(\displaystyle V=2\cdot\frac{\pi}{3}\left(\frac{1}{2}\right)^2(1)=\frac{\pi}{6}\)
If I we going to do this using the calculus, I would shift the function 1 unit to the left, and then use the even function rule to write:
\(\displaystyle V=2\pi\int_0^1 \frac{1}{4}x^2\,dx=\frac{\pi}{2}\left[\frac{x^3}{3}\right]_0^1=\frac{\pi}{6}\)
A slightly different approach:
Since you're squaring, there's no difference between the two integrands. Consider what the problem is geometrically: two cones with base radius 1/2 and height 1. Thus, we need to calculate
\(\displaystyle 2\cdot\pi\int_0^1\left[\dfrac12(1-x)\right]^2\,dx\)
or (neatly),
\(\displaystyle \dfrac{\pi}{2}\int_0^1(1-x)^2\,dx=\dfrac{\pi}{6}\)
FAQ: Volume enclosed by rotating a curve segment
What is the formula for finding the volume enclosed by rotating a curve segment?
The formula for finding the volume enclosed by rotating a curve segment is V = π∫a^b (f(x))^2 dx, where f(x) is the function defining the curve, a and b are the limits of integration, and π is a constant representing pi.
How do you determine the limits of integration when finding the volume enclosed by rotating a curve segment?
The limits of integration are determined by the points where the curve intersects the axis of rotation. These points will be used as the a and b values in the formula.
Can the volume enclosed by rotating a curve segment be negative?
No, the volume enclosed by rotating a curve segment is always a positive value. This is because the integral of a squared function will always result in a positive value.
What is the difference between using the disk method and the washer method to find the volume enclosed by rotating a curve segment?
The disk method is used when the curve is rotated around the x-axis, while the washer method is used when the curve is rotated around a horizontal or vertical line other than the x-axis. The formula and limits of integration used in each method will differ accordingly.
Can the volume enclosed by rotating a curve segment be found if the curve is not a function?
Yes, the volume enclosed by rotating a curve segment can still be found if the curve is not a function. In this case, the formula will be modified to V = π∫c^d (g(y))^2 dy, where g(y) is the function defining the curve, and c and d are the limits of integration determined by the points of intersection with the axis of rotation.
