Volume enclosed by two paraboloids
  • Thread starter DieCommie
  • Tags
    Volume
In summary, the conversation discusses finding the volume enclosed by two paraboloids, with one being upward opening and the other downward opening. The speaker is having difficulty understanding which function to integrate and their teacher suggests integrating the difference between the two paraboloid equations. However, the speaker is unsure why this is the correct approach and wonders if switching the order of the difference would give a different result.
DieCommie
157
Hello, I have to find the volume enclosed by two paraboloids -
[tex] z = 9(x^2+y^2) [/tex] and [tex] z = 32-9(x^2+y^2) [/tex]
I found the limits of integraion by setting them equal to each other. The problem I am having is what function do I integrate?
The example my teacher gave, he integrated [tex]32-9(x^2+y^2) - 9(x^2+y^2) [/tex], the difference of the two paraboloid equations. I am sure this is right, but I don't understand why. Wouldnt integrating the difference of the paraboloids be the total volume minus the volume enclosed by the two paraboloids?:confused:
not if you take the difference in the right direction
The way I have it above, it is the volume of the downward opening paraboloid minus the volume of the upward opening paraboloid. This would leave the downward opening paraboloid minus its top.
Switching the order of the difference would give me the volume of the upward opening paraboloid minus the volume of the downward opening parabolodi. This would leave teh upward opening paraboloid minus its bottom.
or not?
FAQ: Volume enclosed by two paraboloids
What is the formula for finding the volume enclosed by two paraboloids?
The formula for finding the volume enclosed by two paraboloids is V = 2/3πa^2h, where "a" is the radius of the base of the paraboloids and "h" is the height of the paraboloids.
How do you determine the radius of the base of the paraboloids?
The radius of the base of the paraboloids can be determined by finding the distance between the two paraboloids at the point where they intersect. This distance will be equal to the radius of the base.
Can the volume enclosed by two paraboloids be negative?
No, the volume enclosed by two paraboloids cannot be negative. Volume is a measure of space and cannot have a negative value.
What is the significance of finding the volume enclosed by two paraboloids?
Calculating the volume enclosed by two paraboloids can be useful in various applications, such as in engineering and architecture. It can also be used to solve real-life problems involving curved surfaces.
Are there any other methods for finding the volume enclosed by two paraboloids?
Yes, there are other methods for finding the volume enclosed by two paraboloids, such as using calculus or using integration. However, the formula V = 2/3πa^2h is the most commonly used method.
