How to Set Up a Triple Integral for Volume in the First Octant?
  • MHB
  • Thread starter harpazo
  • Tags
    Volume
In summary, we are asked to find the volume of a solid bounded by the graphs of the equations z = 4 - x^2 and y = 4 - x^2 in the first octant. The triple integral set up for this problem involves setting the lower bound for each variable as 0, and the upper bound for x as 2 and for y as 4 - x^2. After evaluating the integral, the answer is 64/35, which differs from the textbook answer of 256/15.
harpazo
208
Use a triple integral to find the volume of the solid bounded by the graphs of the equations.
z = 4 - x^2, y = 4 - x^2, first octant
I need help setting up the triple integral for the volume. I will do the rest.
z = 4 - y^2, y = 4 - x^2, first octant
Well as you know it's bounded in the first octant, that means all variables are nonnegative, so the lower bound for each variable is 0.
So we could have $\displaystyle \begin{align*} 0 \leq z \leq 4 - y^2 \end{align*}$.
Now as we know the upper bound for y is $\displaystyle \begin{align*} y = 4 - x^2 \end{align*}$, a parabola with x intercepts -2 and 2, that means $\displaystyle \begin{align*} 0 \leq y \leq 4 - x^2 \end{align*}$ and $\displaystyle \begin{align*} 0 \leq x \leq 2 \end{align*}$. Thus the volume integral is
$\displaystyle \begin{align*} V &= \int_0^2{\int_0^{4 - x^2}{\int_0^{4 - y^2}{\,\mathrm{d}z}\,\mathrm{d}y}\,\mathrm{d}x} \\ &= \int_0^2{\int_0^{4 - x^2}{\left[ z \right] _0^{4 - y^2}\,\mathrm{d}y}\,\mathrm{d}x} \\ &= \int_0^2{\int_0^{4 - x^2}{\left( 4 - y^2 - 0 \right) \,\mathrm{d}y}\,\mathrm{d}x} \\ &= \int_0^2{ \int_0^{4 - x^2}{ \left( 4 - y^2 \right) \,\mathrm{d}y } \,\mathrm{d}x} \\ &= \int_0^2{ \left[ 4\,y - \frac{1}{3}\,y^3 \right]_0^{4 - x^2} \,\mathrm{d}x } \\ &= \int_0^2{ \left\{ \left[ 4 \left( 4 - x^2 \right) - \frac{1}{3} \left( 4 - x^2 \right) ^3 \right] - \left[ 4 \left( 0 \right) - \frac{1}{3} \left( 0 \right) ^3 \right] \right\} \,\mathrm{d}x } \\ &= \int_0^2{ \left[ 16 - 4\,x^2 - \frac{1}{3} \left( 64 - 48\,x^2 + 12\,x^4 - x^6 \right) \right] \,\mathrm{d}x } \\ &= \int_0^2{ \left( 16 - 4\,x^2 - \frac{64}{3} + 16\,x^2 - 4\,x^4 + \frac{1}{3}\,x^6 \right) \,\mathrm{d}x } \\ &= \int_0^2{ \left( \frac{1}{3}\,x^6 - 4\,x^4 + 12\,x^2 - \frac{18}{3} \right) \,\mathrm{d}x } \\ &= \left[ \frac{1}{21}\,x^7 - \frac{4}{5}\,x^5 + 4\,x^3 - \frac{18}{3}\,x \right] _0^2 \\ &= \left[ \frac{1}{21}\left( 2 \right) ^7 - \frac{4}{5} \left( 2 \right) ^5 + 4 \left( 2 \right) ^3 - \frac{18}{3} \left( 2 \right) \right] - \left[ \frac{1}{21} \left( 0 \right) ^7 - \frac{4}{5} \left( 0 \right) ^5 + 4 \left( 0 \right) ^3 - \frac{18}{3} \left( 0 \right) \right] \\ &= \frac{128}{21} - \frac{128}{5} + 32 - \frac{36}{3} - 0 \\ &= \frac{640}{105} - \frac{2688}{105} + \frac{3360}{105} - \frac{1260}{105} \\ &= \frac{52}{105} \end{align*}$
Fabulous work but the textbook answer is 256/15.
I think you are confusing this problem with another you posted. However, when I ask W|A to evaluate the triple integral set up by Prove It, it spits out:
\(\displaystyle I=\frac{64}{35}\)
I just saw my typo. See my edited question.
z = 4 - x^2 not z = 4 - y^2
I also plugged into W.A. and the answer given is 64/35 but the textbook answer is 256/15.
Related to How to Set Up a Triple Integral for Volume in the First Octant?
What is triple integral volume?
Triple integral volume is a mathematical concept used to calculate the volume of a three-dimensional object. It involves integrating a function over a three-dimensional region, using three sets of variables to represent each dimension.
How do you set up a triple integral for volume?
To set up a triple integral for volume, you need to define the limits of integration for each of the three variables (x, y, and z) and identify the function to be integrated. The limits of integration are typically the boundaries of the three-dimensional region.
What is the difference between triple integral volume and surface area?
Triple integral volume calculates the amount of space enclosed by a three-dimensional object, while surface area calculates the amount of space taken up by the surface of that object. In other words, volume measures the interior space, while surface area measures the exterior space.
What are some real-world applications of triple integral volume?
Triple integral volume has various real-world applications, such as calculating the volume of a water tank, determining the amount of medicine in a pill, or calculating the amount of air in a room. It is also used in engineering and physics to calculate the volume of complex shapes and objects.
What are the limitations of using triple integral volume?
One limitation of using triple integral volume is that it can only be applied to objects with a defined boundary. Additionally, the calculation can become complex and time-consuming for irregularly shaped objects. It also assumes that the object has a constant density, which may not always be the case in real-world situations.
  • Calculus
9K
