Volume of 4-ball by Cavalieri's principle?
In summary, Cavalieri's principle states that the volume of a sphere is proportional to the surface area of the sphere.
yucheng
232
57
Find the volume of a 4-space ball, with radius R.
(Alternatively you can integrate this via Cavalieri’s principle, by using the fact that the crosssectional volume is given by ##\frac{4}{3} \pi r^3##
, the volume of a 3-ball)
See example at end of page 1 of https://www.math.ucla.edu/~bonsoon/math32bh.winter2020/notes/short_notes_-_More_on_Change_of_variables_formula.pdf
N/A
I tried integrating the 4-volume of a 4-hemisphere, that is, $$\int^{R}_{0} \frac{4}{3} \pi r^3 dw$$ (along w-axis), since ##r## is proportional to ##w##, where ##r=\frac{w}{R} R##, ##r=w##, thus the integral becomes $$\int^{R}_{0} \frac{4}{3} \pi w^3 dw = \frac{\pi}{3} R^4$$ The volume of a 4-D hypersphere is ##\frac{2\pi}{3} R^4##
Clearly, something is not right.
fresh_42 said:
Are you sure you use the correct formula? I do not see this, neither on what you linked to, nor on Wikipedia:
https://en.wikipedia.org/wiki/N-sphere#Spherical_volume_and_area_elements
https://de.wikipedia.org/wiki/Sphäre_(Mathematik)#Inhalt_und_Volumen
Do you have a description of Cavalieri's principle? It is not explained in your paper.
I don't know the correct formula. I just tried integrating :))) and it failed :\
Just to confirm, a hypersphere has something called a 'radius' right? What I essentially tried was to use the cross sectional volume, integrate across a hemisphere, and see where it goes...
I thought I could do it analogous to integrating the disks in a sphere.
On the top of page 2, it my link in the homework statement states that you can get the volume equation by using Cavalieri's principle. I just took it as a challenge.
@fresh_42 I realized I could not even calculate the volume of the 3-ball with my argument. Looks like it must have been wrong!
fresh_42 said:
the German version has a closed formula
Do you always look at German versions?
I look at all versions I can read a bit. English and German are those with the most pages. But I also look at Spanish, French or Italian if I see a chance to find a better version, mostly a better formula. Formulas can be read in any language, hence I do not care the explanations very much and just look at the math.
I made the experience that the English version is often more theoretical and abstract, whereas the German version tends to provide good formulas and specific examples. I also use Wikipedia for translations: technical terms (search the word you know in your native language and then switch to English) as well as for the correct spelling of names (Ångström, de L'Hôpital, Gauß etc.).
Likes Keith_McClary, docnet and yucheng
I think if you try to repeat this for calculating the area of a circle you will find your mistake. You don't have the right radius of the 3-ball as a function of where you are in the 4-ball.
  • Skeptical
Likes yucheng and Keith_McClary
let me try, ##r=\sqrt{x^2+y^2}##, ##y=\sqrt{r^2-x^2}##,
\begin{align*}
\int \frac{4}{3} \pi y^3 dx &= \frac{4}{3} \pi \int^{r}_{-r} (r^2-x^2)^{3/2} dx\\
&= (\frac{4}{3} \pi)(\frac{3}{8} \pi r^4) \\
&= \frac{1}{2} \pi^2 r^4
\end{align*}
Somehow, I spent a lot of time wondering whether this is the correct integral, when I could have just plugged it into Mathematica to check :-\
Anyway, thanks!
Related to Volume of 4-ball by Cavalieri's principle?
1. What is Cavalieri's principle?
Cavalieri's principle is a geometric principle that states that if two three-dimensional figures have the same cross-sectional area at every level, then they have the same volume.
2. How is Cavalieri's principle used to calculate the volume of a 4-ball?
Cavalieri's principle can be used to calculate the volume of a 4-ball by breaking it down into a series of cross-sections. By finding the area of each cross-section and adding them together, the volume of the 4-ball can be determined.
3. What is a 4-ball?
A 4-ball, also known as a four-dimensional ball, is a four-dimensional shape that is bounded by a three-dimensional sphere. It is a theoretical shape that cannot be visualized in our three-dimensional world.
4. Can Cavalieri's principle be applied to other shapes besides the 4-ball?
Yes, Cavalieri's principle can be applied to any two three-dimensional figures that have the same cross-sectional area at every level. It is a useful tool in calculating the volume of irregular shapes.
5. What are the limitations of using Cavalieri's principle to calculate the volume of a 4-ball?
One limitation is that it can be difficult to accurately calculate the cross-sectional area at every level, especially for complex shapes. Additionally, Cavalieri's principle only works for shapes that have the same cross-sectional area, so it cannot be applied to all shapes.
