Volume of a Pond (Triple Integral)
In summary: Thanks guys,In summary, the total volume of the pond is larger when the pond shape is a paraboloid rather than a hemisphere.
Woolyabyss
143
A circular pond with radius 1 metre and a maximum depth of 1 metre has the shape of a paraboloid, so that its depth z is z = x 2 + y 2 − 1. What is the total volume of the pond? How does this compare with the case where the pond has the same radius but has the shape of a hemisphere?
n/a
\int _{-1}^0\left(\int _{-\sqrt{1-x^2}}^{\sqrt{1-x^2}}\left(\int _{x^2+y^2-1}^0\left(\right)dz\right)dy\right)dx
I was just wondering if this triple integral accurately describes what the question is asking? I searched online but can't find any anything similar.
n/a
$$\int _{-1}^0\left(\int _{-\sqrt{1-x^2}}^{\sqrt{1-x^2}}\left(\int _{x^2+y^2-1}^0\left(\right)dz\right)dy\right)dx$$
Now (with the ##\$\$## around the ##\TeX##) it looks OK. You can see the bounds sitting there properly.
Likes Woolyabyss
Doesn't seem to work. If you want to integrate in Cartesian variables, you should identify the correct limits for each variable. I suggest that you work in cylindrical coordinate instead, because in this case there is only one variable whose integration limits are a function of the other two variables.
Likes Woolyabyss
So in cylindrical coordinates if we integrate in the order z,r,θ
would the limits be r-1 to 0,-r to r and 0 to 2*pi?
EDIT
or should it be r-1 to 0,0 to r and 0 to 2*pi?
Neither. z is not r-1 to 0 (that would be a cone)
(PS post #2 only said something about the look of things..., not the solubility)
Likes Woolyabyss
is it r^2 -1 to 0 ,0 to r and 0 to 2*pi?
For your purpose, it will be helpful to think of the pond as being made of a stack of infinitesimally thick disks put on top of another in z direction such that they form a paraboloidal volume. Now consider a disk located at a fixed plane ##z##. The thickness of this disk is ##dz##. For the area of this disk, how will you calculate it using the integral in polar coordinate ##r##, ##\theta##? To do this, first you need to express the radius of this disk as a function of ##z##.
Likes Woolyabyss
Thanks guys,
I realized in my original integral x should have been from -1 to 1 and not 0 to 1. also in polar coordinates if I use is it r^2 -1 to 0 ,0 to 1 and 0 to 2*pi, I get the same answer of (1/2)*pi
Related to Volume of a Pond (Triple Integral)
1. What is the formula for calculating the volume of a pond using triple integrals?
The formula for calculating the volume of a pond using triple integrals is V = ∭ f(x,y,z) dV, where f(x,y,z) is the function representing the shape of the pond and dV is the infinitesimal volume element.
2. How do you set up the bounds for a triple integral when calculating the volume of a pond?
The bounds for a triple integral when calculating the volume of a pond depend on the shape and dimensions of the pond. Generally, the bounds for x, y, and z will correspond to the width, length, and depth of the pond, respectively. These bounds can be determined by visualizing the pond and understanding the limits of the x, y, and z coordinates within that space.
3. Can the volume of a pond be calculated using a single integral?
No, the volume of a pond cannot be calculated using a single integral. A single integral only accounts for one variable, whereas the volume of a pond is determined by three variables (x, y, and z) and thus requires a triple integral.
4. How is the volume of a pond affected by changes in its depth?
The volume of a pond is directly affected by changes in its depth. As the depth of the pond increases, the volume also increases. This relationship can be visualized by imagining a cube of water and increasing its depth, which would result in an increase in volume.
5. Are there any real-world applications of calculating the volume of a pond using triple integrals?
Yes, calculating the volume of a pond using triple integrals has many real-world applications, especially in fields such as hydrology and environmental science. Understanding the volume of a pond is crucial for managing water resources, predicting flood risk, and designing irrigation systems.
