Galadirith
- 109
EDIT: [so sorry guys i thought I had clicked h/w c/w calculus section, if any admin could move this thread there that would be really appreciated, sorry for posting in the wrong sub-forum]
Hi guys, I am having an issue with the volume of a sphere and calculating it. I am using the method where the solid, sphere in this case, is composed of many cylinders, in my case along the x-axis where the center of the sphere is at the origin.
So initially I attempted this by considering each cylinder was of volume:[itex]\pi y^2 \delta x [/itex]
then the formula of the circle in the xy plane of the sphere is [itex]x^2 + y^2 = r^2[/itex] which yields [itex]y^2 = {r^2 - x^2} [/itex] which means the volume of each cylinder becomes [itex]\pi (r^2 - x^2) \delta x[/itex]
I will limit my range to [0,r] as it is symmetrical about the yz plane. So integrating accros the interval [0,r] we get :
[tex]V = \pi \int_{0}^{r} (r^2 - x^2) \delta x [/tex]
[tex] = \pi ({r^2}x - \frac{x^3}{3})\bigg{|}_0^r [/tex]
[tex] = \pi [({r^3} - \frac{r^3}{3})-({r^3}(0) - \frac{0^3}{3})] [/tex]
[tex] = \pi \frac{2r^3}{3}[/tex]
then x2 to get the volume of a sphere to be [itex]{4\pi r^3}{/}{3}[/itex]
now that's all well and good, but I also wanted to see if another method would work, instead of using x as our independent use theta. Now I learned that if you wanted to calculate the surface are of a sphere you can use theta as it makes calculations easier. So using the idea that we can calculate the surface are of a sphere modeling it as composed of many hollow and cylinders with no base or head, each has height [itex]r\delta \theta[/itex]. So each cylindrical surface becomes :
[tex]i. \ A = 2\pi y r \delta \theta[/tex]
[tex]ii. \ y=rsin\theta[/tex]
[tex]iii. \ A = 2r\pi rsin\theta \delta \theta[/tex]
So that's fine, that idea can be taken as can successfully yield the surface area of a sphere successfully. Now I figured if that method can be employed for a surface, it must be adaptable to find the volume of a sphere. so this time I decided to define each solid cylinder as:
[tex]iv. \ V = \pi y^2 r \delta \theta[/tex]
[tex]v. \ V = r\pi (r^2sin^2\theta) \delta \theta [/tex]
so again I approached this as before, this time integrating across the range [0, [itex]\pi / 2[/itex]] where I again will only find the hemisphere for +ve x and theta is the angle from the x axis. So my integration went like this :
[tex]V = \pi r^3\int_{0}^{\frac{\pi}{2}} (sin^2\theta) \delta \theta [/tex]
[tex] = \pi r^3\int_{0}^{\frac{\pi}{2}} \frac{1}{2}(1 - cos2\theta) \delta \theta [/tex]
[tex] = \frac{\pi r^3}{2}(\theta - \frac{1}{2}sin2\theta)\bigg{|}_{0}^{\frac{\pi}{2}}[/tex]
[tex] = \frac{\pi r^3}{2}(\frac{\pi}{2}) = \frac{\pi^2 r^3}{4} [/tex]
then oviously x2, but as is evident it is not the right answer, I really can't see what I have done wrong, I pretty sure none of my actually mathematics is wrong, which means the only part that could be wrong is the [itex]r\delta \theta[/itex] bit and teacher suggested that for some reason it doesn't apply to a solid but does to a shell, but couldn't give a valid reason as to why. I am inclined to agree with him, but again I can't see why. In various texts I have looked though it says things along the lines of for the shell it is tempting to use [itex]\delta x[/itex] but that [itex]r\delta \theta[/itex] is a "better approximation", therefore surely it to is a better approximation for a solid of revolution to.
Can anyone explain why this is, what is the reason the integration can't be done this way, or am have I simply done my maths wrong, thanks guys :D
