Volume of a square using cross section
In summary, the problem involves finding the volume of the area bounded by two curves where the cross sections are perpendicular to the y-axis. The solution will involve taking an integral with respect to y, rather than x.
mikaloveskero
What is the volume if the area bounded by y=x^2 and y=9 and the cross sections are perpendicular to the y axis
I have no idea
At least draw the graph and make an attempt. Take a picture of it or scan it or just draw it in some picture editor and attach it to your post.
I drew the picture and y=9 is the higher graph and y=x^2 is the lower graph. So from there do you do (9-x^2)^2 and take the integral from -3 to 3 ?
The cross sections are perpendicular to the y-axis, not parallel. So the integral will be with respect to y, not x.
FAQ: Volume of a square using cross section
What is the formula for finding the volume of a square using cross section?
The formula for finding the volume of a square using cross section is V = A * h, where V is the volume, A is the area of the square, and h is the height of the cross section.
Can the volume of a square using cross section be calculated if the cross section is not a perfect square?
Yes, the volume can still be calculated as long as the cross section has a known area and the height is perpendicular to the base of the square.
How does the volume of a square using cross section differ from the volume of a regular square?
The volume of a regular square is calculated by multiplying the length, width, and height, while the volume of a square using cross section is calculated by multiplying the area of the square and the height of the cross section.
Can the volume of a square using cross section be negative?
No, the volume cannot be negative as it is a measure of space and cannot have a negative value.
Are there any real-world applications of calculating the volume of a square using cross section?
Yes, this concept is commonly used in construction to calculate the volume of objects with a square base, such as buildings or containers. It is also used in engineering and manufacturing to determine the volume of square-shaped objects.
