Volume of cube with three holes
In summary, a problem has been presented involving a 1" cube with three 1/2" diameter holes drilled in it. The remaining volume of the cube is being sought after. One user has calculated the solution for two holes, while another has found the shape in the center to be a Steinmetz Solid with a specific volume. However, there seems to be a discrepancy between the calculated volume and the volume found through a 3DCAD model. The conversation then delves into trying to solve the problem using calculus and set theory. Ultimately, the final volume of the holey cube is determined to be 0.5877, with the correct approach being to subtract the volumes of the cylinders and add the volume of the intersection
  • #36
I may be repeating someone here, but I scanned the above posts and didn't see any reference to this:
It may be easier to think of the cube kind of like a Rubik's cube. Cut it into sections such that only a 1/2" cube remains in the center. Determine the volume of the removed parts first. Then work on the center piece separately.
Mathematics news on Phys.org
  • #37
I mean, we have two solutions, one analytical using calculus, and one geometric numerical. I think this problem has been taken care of? Unless there are other cool methods to solve it.
  • #38
There is nothing wrong with using calculus, of course. When I was given the problem (40 years ago) the statement of the problem indicated no advance maths. or computer programs to be used (there were no PCs then in any case). I think that the calculus method must be much shorter than mine. While the error term in my formula allows me to calculate the solution to any required accuracy, I think it removed elegance to the sectioning method, which could only get the right answer to 2 decimal places.
The person, incidentally, who gave me the problem did not have the solution. I wonder if he ever solved it.
  • #39
Yes, there is another method of solving the problem, as given by a silly old engineering colleague: Fill the holes in the cube with a liquid and then pour the liquid into a measuring cylinder!
