Xishem
- 13
Volume of Frustum Using Triple Integral [Solved]
Edit: I've solved the issue! My limits of r were wrong. Instead of this:
[tex]V=\int_{z=0}^{\frac{h}{2}}\int_{r=0}^{\frac{R}{h}z+R}\int_{\theta=0}^{2\pi}r\ d\theta\ dr\ dz[/tex]It should have been this:
[tex]V=\int_{z=0}^{\frac{h}{2}}\int_{r=0}^{\frac{-R}{h}z+R}\int_{\theta=0}^{2\pi}r\ d\theta\ dr\ dz[/tex]
I'm trying to find the volume of a frustum using strictly a triple integration in cylindrical coordinates. I've been able to find the volume through several other methods, but whenever I try to do it using a triple integration, it fails to produce the correct result.
The semi-specific frustum I'm looking at has the following properties:
[itex]height = \frac{h}{2}[/itex]
[itex]radius_{bottom} = R[/itex]
[itex]radius_{top}=\frac{R}{2}[/itex]
[tex]dV=r\ dr\ d\theta\ dz[/tex]
I've tried setting up several integrations, but they have all failed. For me, the difficult part comes in setting the limits of each integral. From what I understand, the general form of the integral will look like this:
[itex]V=\int\int\int\ r\ dr\ d\theta\ dz[/itex]
And my attempt at putting in limits is...
The limits of r are derived from the slope of one of the sides of the frustum projected onto a 2D plane.
Where the function of that line can be described as:
[itex]y=\frac{R}{h}z+R[/itex]
And the radius (r) is directly related to y in that
[itex]y=r[/itex]
I've tried doing this integration, and I don't know what my final answer is as I've gone through so many iterations of different integrations that things have been blurred. The answer I get is correct in terms of variables, but incorrect in terms of a constant factor, if I remember correctly.
Any help on the limits, or the integrand in general? Thanks!
[itex]y=r[/itex]
