Volume of liquid in a tank using a double integral
In summary, the volume of liquid in a tank can be calculated by integrating the cross-sectional area with respect to the height of the liquid using a double integral. This method involves variables such as the liquid height, cross-sectional area, and tank dimensions. It can be used for irregularly shaped tanks by breaking down the cross-sectional area into simpler shapes. The density of the liquid does not directly affect the calculation, but must be taken into account for correct unit conversion. While the double integral method is very accurate, other methods may also provide accurate results depending on the tank's shape and dimensions.
mathmath
The fluid level in the tank ((1/4)*(x-4)^2 + y^2 == 4) is 7 m on the left edge of the tank (where x=0) and 5 m on the right edge (where x=8). Find the equation of the plane of the liquid, and use a double integral to find the volume of liquid in the tank. [Hint: you should use a "dy dx" iterated integral, where the bounds on y depend on x, and are given by the equation of the base of the cylinder.]
tank equation: (1/4)*(x-4)^2 + y^2 == 4
I have found the equation of the plane of liquid to be: z=7 - 2 x/8, I am not sure if this is correct. I am confused on what the bounds would be for the double integral and what would be the integrand since the tank equation is set equal to a number.
Thanks!
Dear forum post author,
Thank you for sharing your problem with us. You are on the right track with your equation for the plane of liquid. To find the volume of liquid in the tank, we can use a double integral with the bounds of integration being the base of the tank and the top surface of the liquid.
To set up the double integral, we first need to express the tank equation in terms of y. We can rearrange the equation to get y = ±√(4 - (1/4)*(x-4)^2). This gives us the bounds of integration for y as ±√(4 - (1/4)*(x-4)^2). For the bounds of integration for x, we can use 0 and 8, since those are the left and right edges of the tank.
Now, for the integrand, we can use the equation of the plane of liquid that you found, z = 7 - 2x/8. This will give us the height of the liquid at any point (x,y) in the tank.
Putting it all together, we get the double integral:
∫∫[7 - 2x/8] dy dx
Where the bounds of integration are:
0 ≤ x ≤ 8
-√(4 - (1/4)*(x-4)^2) ≤ y ≤ √(4 - (1/4)*(x-4)^2)
Evaluating this integral will give us the volume of liquid in the tank.
I hope this helps. Good luck with your calculations!
Related to Volume of liquid in a tank using a double integral
1. How do you calculate the volume of liquid in a tank using a double integral?
The volume of liquid in a tank can be calculated by integrating the cross-sectional area of the tank with respect to the height of the liquid. This can be represented by a double integral, where the inner integral calculates the area of the tank at a specific height, and the outer integral integrates the area over the entire height of the tank.
2. What are the variables involved in the double integral for calculating volume of liquid in a tank?
The variables involved in the double integral for calculating volume of liquid in a tank are the height of the liquid (represented by the limits of the outer integral), the cross-sectional area of the tank (represented by the integrand of the inner integral), and the dimensions of the tank (which are used to determine the limits of the inner integral).
3. Can the double integral method be used for irregularly shaped tanks?
Yes, the double integral method can be used for irregularly shaped tanks. However, the calculation may be more complex as the cross-sectional area may vary at different heights. In this case, the cross-sectional area can be divided into smaller, simpler shapes (such as rectangles or triangles) and integrated separately.
4. How does the density of the liquid affect the calculation of volume using a double integral?
The density of the liquid does not directly affect the calculation of volume using a double integral. However, it is important to take into account when determining the units of the integrand in order to get the correct units for the final volume result. For example, if the density is in kilograms per cubic meter, the cross-sectional area must also be in square meters in order to get the final volume in cubic meters.
5. Is the double integral method the most accurate way to calculate the volume of liquid in a tank?
The double integral method is a very accurate way to calculate the volume of liquid in a tank, as it takes into account the varying cross-sectional area at different heights. However, other methods such as using a formula for the volume of a partially-filled cylinder or using a 3D modeling software may also provide accurate results depending on the shape and dimensions of the tank.
