Volume of revolution integral question
In summary, the jeweller must first calculate the volume of the desired wedding band to determine how much gold will be required. The volume of the wedding band is given by the equation V = \pi W(2RT+T^2) + \pi\frac 43\left(\frac W2\right)^{2 \cdot \frac 32}.
arc1
This project deals with custom made gold wedding bands. Its shape is obtained by revolving the region shown about a horizontal axis. The resulting band has Inner radius R, Minimum Thickness T, Width W.
The curved boundary of the region is an arc of a circle whose center lies on the axis of revolution. For a typical wedding band with given dimensions R, T, W, the jeweller must first calculate the volume of the desired wedding band to determine how much gold will be required.
Show that the volume V is given by the formula
[tex]\frac {\pi W}{6} (W^2 + 12RT + 6T^2)[/tex]
[tex]x^2 + y^2 = R^2[/tex]
First i tried to use the shell method and came up with this:
[tex]2 \cdot 2\pi \left(\int_{R}^{(R+T)}x\frac w2 \,dx + \int_{(R+T)}^{b}x\sqrt{b^2-x^2} \, dx \right)[/tex]
where b is the radius of the curved boundary
and that led to this:
[tex]\pi W(2RT+T^2) + \pi\frac 43(b^2 -(R+T)^2)[/tex]
But now i got stuck. I don't know what to do about the b.
I don't even know if I'm on the right track now.
This is confusing. In your picture "R" appears to be distance from the axis of revolution to the inner edge of the "ring". If that is true, then R is not the radius of the circle forming the outer edge. If R is the radius of that circle (as in the equation just above) what is the distance from the inner edge to the axis of revolution?
Good start, you've got the integral set up right. To find b draw a right triangle whose hypotenuse connects the center point on the axis to the endpoint of the arc. One side is (R+T), the other side is W/2 and the hypotenuse is b. Now you can find b. And did you mean to have a 3/2 power on the b^2-(R+T)^2?
If you look at the working of the problem the OP is using b to denote the radius of the arc. Probably should have labeled that in the picture. The problem is actually almost done!
Thanks Dick.
Your help made it easy.
And you're right it was supposed to be like this:
[tex]V = \pi W(2RT+T^2) + \pi\frac 43(b^2 -(R+T)^2)^{\frac 32}[/tex]
And I continue:
[tex]b^2 = (R+T)^2 + (\frac W2)^2[/tex]
[tex]V = \pi W(2RT+T^2) + \pi\frac 43((R+T)^2 + \left(\frac W2\right)^2 -(R+T)^2)^{\frac 32}[/tex]
[tex]V = \pi W(2RT+T^2) + \pi\frac 43\left(\frac W2\right)^{2 \cdot \frac 32}[/tex]
[tex]V = \pi \left(W(2RT+T^2) + \frac {W^3}{6}\right)[/tex]
[tex]\underline{\underline{V = \frac{\pi W}{6} \left(W^2 + 12RT + 6T^2 \right)}}[/tex]
Bingo. You are pretty good.
FAQ: Volume of revolution integral question
How do I find the volume of revolution using an integral?
To find the volume of revolution using an integral, you will need to use the formula V = π ∫ab(f(x))^2 dx, where a and b are the limits of integration and f(x) is the function being rotated around the axis.
What is the difference between disk and washer methods for finding volume of revolution?
The disk method is used when the cross-section of the solid is a circle, while the washer method is used when the cross-section is a ring. The washer method is more versatile as it can be used for solids with non-circular cross-sections.
Can I use the volume of revolution integral for finding the volume of a solid with a hole in it?
Yes, you can use the volume of revolution integral for finding the volume of a solid with a hole in it by using the washer method. The hole will be represented as a negative value in the integral.
What if the function being rotated is not in terms of x?
If the function is in terms of y, you will need to rearrange the integral to be in terms of x. This can be done by expressing the function in terms of x and solving for y. The limits of integration may also need to be adjusted accordingly.
How do I know which axis to rotate the function around?
The axis of rotation will usually be specified in the question. If it is not specified, you can determine it by looking at the cross-sections of the solid. For example, if the cross-sections are circles, the axis of rotation will be perpendicular to the x-axis.
