relskid
- 33
find the volume of the solid generated by rotating the circle (x-10)^2 + y^2 = 36 about the y-axis
disk method: [tex]\pi\int [R(x)]^2dx[/tex]
shell method: [tex]2\pi\int (x)(f(x))dx[/tex]
[tex]y = \sqrt{36-(x-10)^2}dx[\tex]
\\\pi\int [(\sqrt{36-(x-10)^2})]^2dx[/tex]
[tex]\pi\int (36-(x-10)^2)dx[/tex]
[tex]\pi\int (36-(x^2-20x-100))dx[/tex]
[tex]\pi\int (-x^2+20x-64)dx[/tex]
[tex]\pi [(\frac{-x^3}{3}+10x^2-64x)][/tex]
ok, as you may have noticed, the integral isn't definite. that's because i don't know whether it should be from 4 to 16, or -6 to 6. also, if i did the entire problem wrong, that'd be nice to know, too. :P
next problem:
a cylindrical gasoline tank is placed so that the axis of the cylinder is horizontal. find the fluid force on a circular end of the tank if the tank is half full, assuming that the diameter is 2 feet and the gasoline weighs 42 pounds per cubic foot.
[tex]F =\int (p)(h(y))(L(y))dy[/tex]
p=rho (density)
[tex]x^2 + y^2 = 2^2[/tex]
[tex]x^2 = 4 - y^2 [/tex]
[tex]x = \sqrt{4 - y^2} [/tex]
note: integration from -1 to 0
[tex]42\int(-y)\sqrt{4 - y^2}dy[/tex]
after that, i don't really know what to do. this is the part that I'm especially not sure about:
[tex]-42\int(y)\sqrt{4 - y^2}dy[/tex]
[tex]u=4-y^2[/tex]
[tex]du=-2ydy[/tex]
[tex]-\frac{1}{2}du=ydy[/tex]
[tex]-42(-\frac{1}{2})\int\sqrt{u}du[/tex]
[tex]21\int\sqrt{u}du[/tex]
[tex]21[\frac{u^\frac{3}{2}}{3/2})][/tex]
