Volumes of a Region bounded by Two Curves
In summary: Thanks for your help!In summary, the region bounded by the curves y = x2 and y = x + 2 has volume 21pi.
doublehh06
1. Let R be the region bounded by the curves y = x2 and y = x + 2.
(a) Sketch the region R and label the points of intersection between the two curves.
(b) Suppose we rotate R about the x-axis. Compute the volume of the resulting solid.
(c) What is the volume of the solid obtained by rotating the region R about the line x = 2?
We need to know the equation for solving volume using a definite integral with the disc method and cylindrical method.
I have part (a). For part (b), I set up the problem using the disc method which is the definite integral from [-1,2] of A(x) dx.
The set up looked like The definite integral from [-1,2] of pi(x+2)2dx.
After solving this, I got 21pi but am doubtful of my answer.
For part (c), I set up the problem using the cylindrical method which is the definite integral from [-1,2] of 2*pi*x (x+2)dx with radius x, circumference 2pi x and height x + 2. I got 12pi but am once again doubtful of my answer.
Am I on the right track? Help please?
When you use the "washer" (disc) method, the volume of the washer is:
[tex]\pi(r_1^2-r_2^2)h[/tex]
where the outer radius, r_1, is the line f(x)=x+2 and the inner radius, r_2, is g(x)=x^2 and the "height" of the infinitesimal disc would be dx since you're integrating with respect to x so the integrand would
[tex]\pi(f^2-g^2)dx[/tex]
right?
Now for the cylindrical shell method, since you're going around the x-axis, can you see where that would require two integrals? The first "inner" integral would be the shells contributed by just the parabola up to the height where the line f=x+2 intersects it. Once you pass that, then the "height" of the shells would be determined by the distance between the line f=x+2 and the right side of the parabola or:
[tex]V=I_1+I_2=\int_0^1 (shell1)dy+\int_1^4 (shell2) dy [/tex]
Maybe that's not very clear. How about just look in the calculus textbook on both of these methods. That would help too.
I have reviewed the topics in the book and feel I have an understanding; however, I have never seen problems like these before and can't relate them to examples in the book. I thought the disc/cylindrical methods may be appropriate, but I am not positive.
When you read the problem itself for the first time, how would you go about solving it?
Thanks.
Thanks.
Hi. I would solve it using the "washer" method. The volume of the infinitesimal washer is:
right?
So then just integrate over the range -1 to 2.
That sounds right for part (B); however, would you use the same method for part (c)? Or would you try something else?
Hi Double. Sorry I'm not able to get to the web much these days. Maybe you've solved this already. Anyway, part C would best be solved using cylindrical shells and would only take one integral.
FAQ: Volumes of a Region bounded by Two Curves
1. What is the formula for finding the volume of a region bounded by two curves?
The formula for finding the volume of a region bounded by two curves is ∫[a,b] A(x) - B(x) dx, where A(x) and B(x) are the upper and lower curves, respectively, and a and b are the x-values of the region's boundaries.
2. How do you determine which curve is the upper and lower curve?
The upper and lower curves can be determined by looking at the y-values of the curves. The upper curve will have a higher y-value than the lower curve at any given x-value. Alternatively, you can also graph the curves and visually determine which is the upper and lower curve.
3. Can the region bounded by two curves have a negative volume?
No, the volume of a region bounded by two curves cannot be negative. The volume is always a positive quantity, representing the amount of space enclosed by the two curves.
4. What is the relationship between the volume of a region bounded by two curves and the area between the same two curves?
The volume of a region bounded by two curves is directly related to the area between the same two curves. The volume is simply the area between the curves multiplied by the distance between the boundaries in the direction perpendicular to the x-axis.
5. Can the region bounded by two curves be rotated to find the volume?
Yes, the region bounded by two curves can be rotated around a given axis to find the volume. This is known as the method of cylindrical shells and involves integrating the circumference of the shell multiplied by its height. This method is particularly useful for regions with curved boundaries.
