RJLiberator
- 63
Compute the region R in the first quadrant between y=e^(-x), x=0, and y=0. Compute using shells, the volume V of solid around the y-axis.
Volume =integral of bounds 2pi*radius*height
First I drew the graph. This graph really is just a graph of e^(-x).
I then visually rotated it around the y-axis.
This problem seems easy enough to set up:
Volume = Integral between 0 (lower limit) and infinity (upper limit) of 2*pi*x*e^-(x) dx
where x = radius
dx = width
e^(-x) = height
This problem was also easy to integrate using integral substitution first, and then integration by parts one time. The final equation was
V = 2pi[-xe^(-x)-e^(-x)] from 0 to infinity.
After calculating the simple answer is 2pi.My problem: For some reason, when I use this calculator: http://www.wolframalpha.com/widgets/view.jsp?id=1cd73be1e256a7405516501e94e892ac
I get an answer of pi/2.
Am I doing something wrong? Or is my answer/thinking correct?
Thank you.
