VSD for induction motor maximum current
In summary: So, at high speed, the power required to overcome static friction (and therefore propel the load) is very high, since static friction dominates at high speed.
tim9000
867
Hi,
I'm trying to ascertain when you're driving an asynchronous motor with VVVF or whatever else a VSD uses, when do you draw the most current?
For instance, say you're talking about a train/tram: I would have thought intuitively that since power = torque / angular speed, that starting up, to move the big mass the motor and system would draw the most power (torque very high, speed very low). But I heard a rumour that the vehicles actually draw the most power when motoring at full speed.
Now, obviously when you're starting up you lower the voltage and the frequency, so is there some sort of algorithm that VSDs use as a standard to draw the most power/current when operating at full speed...some industry profiles I should know about?
Thanks very much!
P.S. I'm not sure what conservation of energy says about keeping a mass moving (overcoming friction etc) at full speed, vs starting a mass to move from stationary.
I'm assuming a typo here.
Horsepower= (torque * RPM)/5252, where torque is in lb-ft.
An alternative formulation is Watts = 2π*torque *RPS, where torque is in Newton meters, and RPS is revolutions per second.
... when do you draw the most current?
It depends upon the characteristics of the driven load.
Let's set that aside for now, and consider a scalar (as opposed to vector) "Volts/Hertz" (V/Hz) inverter drive rated 6 amp continuous current, and a 460 volt/60 Hz/3 PH/1760 RPM motor. These ratings define the basic Volts/Hertz relationship, specifically, 460/60, or 7.67 V/Hz. If commanded speed is 1 Hz (equal to 1/60, or 1.67% full speed = (1/60)*1760, or 29.3 RPM) 7.67 volts is fed to the motor windings; at 2 Hz (3.34% full speed, 58.8 RPM) 15.3 volts is placed across the motor windings, and so on.
3 phase power is 1.732*volts*amps*power factor. To avoid confusion about the core principles, we'll lie a bit, and assume PF = 1.0.
Power is 80 watts at 1 Hz (7.67 volts) and 6 amp continuous current drive rating. If it takes 60 watts to overcome static friction of the load, then the motor shaft will rotate at 29 RPM, and current will drop to about 4.5 amps. Bump speed command to 2 Hz, and (providing load power requirement remains at 60 watts) the motor shaft accelerates to 59 RPM, voltage rises to 15.3 volts, and (because power = volts * amps * 1.732) current falls to 2.3 amps.
80 watts may not be enough power to overcome static load friction. In that case, it depends on drive design. Most drives can source anywhere from 150% to 300% of rated continuous current for brief periods before faulting. Additionally, V/Hz drives are also often designed with some sort of "Voltage Boost" parameter to temporarily violate the V/Hz relationship when under x amount of speed command, and pour on additional voltage. Both these things in combination are usually enough to get the load moving, although it may not be possible to run successfully at very low speed if current demand remains above the continuous rating.
OK, so high current demand will occur at very low speed until the load begins to move.
Depending upon load characteristics, it may also be a limiting factor at higher speeds.
For instance, consider pump and fan affinity laws. Flow rate is proportional to input shaft speed, pressure is proportional to shaft speed squared, and power is proportional to shaft speed cubed.
Related to VSD for induction motor maximum current
1. What is VSD for induction motor maximum current?
VSD stands for Variable Speed Drive and it is used to control the speed of an induction motor. The maximum current refers to the highest amount of electrical current that the VSD can deliver to the motor to achieve a certain speed.
2. Why is it important to know the VSD for induction motor maximum current?
Knowing the VSD for induction motor maximum current is important because it allows us to properly size and select the VSD for the motor. If the VSD cannot provide enough current, the motor may not be able to reach its desired speed and could potentially be damaged.
3. How is the VSD for induction motor maximum current determined?
The VSD for induction motor maximum current is determined by the motor's rated current and the VSD's overload capability. The rated current is the maximum amount of current that the motor can safely handle, and the VSD's overload capability is the maximum amount of current that the VSD can deliver for short periods of time.
4. Can the VSD for induction motor maximum current be changed?
Yes, the VSD for induction motor maximum current can be changed by adjusting the VSD's settings. However, it is important to consult the manufacturer's instructions and follow proper procedures when making any changes to the VSD's settings.
5. What are the consequences of exceeding the VSD for induction motor maximum current?
If the VSD for induction motor maximum current is exceeded, it can lead to overheating and damage to the motor and VSD. It can also cause the VSD to trip and shut down, resulting in downtime and potential loss of production.
  • Electrical Engineering
