MHB VulcaBlack's Inhomogeneous Linear Recurrence Q&A
  • Thread starter Thread starter MarkFL
    Linear Recurrence
The discussion focuses on solving the inhomogeneous linear recurrence relation P(n) = 3P(n-1) + 3n with the initial condition P(0) = 0. A closed-form solution is proposed as P(n) = (3^(n+2) - 6n - 9) / 4, which is verified through mathematical induction. Two alternative methods for deriving the solution are also discussed: symbolic differencing, which transforms the recurrence into a homogeneous form, and the method of undetermined coefficients, which identifies particular solutions. Both methods ultimately confirm the same closed-form solution. The thread provides a comprehensive exploration of techniques for solving such recurrence relations.
MarkFL
MHB
Here is the question:
Given the following recurrence relation, guess a closed-form solution:?
relation: P(n) = { 0 if n = 0
3*P(n-1) + 3n if n>0}
2. prove by induction
please help
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello VulcaBlack,
We are given the following inhomogeneous linear recurrence:
$$P_{n}=3P_{n-1}+3n$$ where $$P_0=0$$
If we are to "guess" a solution, we may look at the first several terms:
$$P_0=0=\frac{3^{0+2}-6\cdot0-9}{4}$$
$$P_1=3\cdot0+3\cdot1=3=\frac{3^{1+2}-6\cdot1-9}{4}$$
$$P_2=3\cdot3+3\cdot2=15=\frac{3^{2+2}-6\cdot2-9}{4}$$
$$P_3=3\cdot15+3\cdot3=54=\frac{3^{3+2}-6\cdot3-9}{4}$$
Thus, we may hypothesize that:
$$P_{n}=\frac{3^{n+2}-6n-9}{4}$$
We have already demonstrated the base case, and a few successive cases to be true, so let's now state the induction hypothesis $P_k$:
$$P_{k}=\frac{3^{k+2}-6k-9}{4}$$
Now, the recurrence relation tells us:
$$P_{k+1}=3P_{k}+3(k+1)$$
Using the induction hypothesis, this becomes:
$$P_{k+1}=3\left(\frac{3^{k+2}-6k-9}{4} \right)+3(k+1)$$
$$P_{k+1}=\frac{3^{k+3}-18k-27+12(k+1)}{4}$$
$$P_{k+1}=\frac{3^{(k+1)+2}-6(k+1)-9}{4}$$
We have derived $P_{k+1}$ from $P_{k}$ thereby completing the proof by induction.
I wish to demonstrate also two techniques for deriving the solution which requires neither guessing, nor proof by induction.
One way to derive a solution is through a technique called symbolic differencing, in which we may transform the recurrence into a homogenous one, and use the characteristic roots to obtain the closed form, and then use the initial values to determine the parameters. Let's begin with the given recurrence:
(1) $$P_{n}=3P_{n-1}+3n$$ where $$P_0=0$$
We may also write the recurrence as:
(2) $$P_{n+1}=3P_{n}+3(n+1)$$
Subtracting (1) from (2), we obtain:
(3) $$P_{n+1}=4P_{n}-3P_{n-1}+3$$
(4) $$P_{n+2}=4P_{n+1}-3P_{n}+3$$
Subtracting (3) from (4), we obtain:
$$P_{n+2}=5P_{n+1}-7P_{m}+3P_{n-1}$$
Now we have a homogeneous recurrence, whose associated characteristic equation is:
$$r^3-5r^2+7r-3=(r-3)(r-1)^2=0$$
Based on the roots and their multiplicities, we may give the closed form as:
$$P_n=k_1+k_2n+k_3\cdot3^n$$
Using the initial values, we may write:
$$P_0=k_1+k_3=0$$
$$P_1=k_1+k_2+3k_3=3$$
$$P_2=k_1+2k_2+9k_3=15$$
Solving this system, we find:
$$k_1=-\frac{9}{4},\,k_2=-\frac{3}{2},\,k_3=\frac{9}{4}$$
Hence, we have:
$$P_n=-\frac{9}{4}-\frac{3}{2}n+\frac{9}{4}\cdot3^n=\frac{3^{n+2}-6n-9}{4}$$
Another way to solve the recurrence is to use the method of undetermined coefficients. We first solve the associated homogeneous recurrence:
$$P_{n}-3P_{n-1}=0$$
which has the characteristic equation:
$$r-3=0$$
Thus, a general solution to the homogeneous equation is:
$$h_{n}=c_13^n$$
Now, since the inhomogeneous term in the original recurrence is $$3n$$, we seek a particular solution of the form:
$$p_{n}=An+B$$
where the parameters $A$ and $B$ are to be determined. Substituting this expression for $P_n$ into the original recurrence, we obtain:
$$(An+B)-3(A(n-1)+B)=3n$$
$$An+B-3(An-A+B)=3n$$
$$An+B-3An+3A-3B=3n$$
$$-2An+(3A-2B)=3n+0$$
Equating coefficients, we find:
$$-2A=3\,\therefore\,A=-\frac{3}{2}$$
$$3A-2B=0\,\therefore\,B=-\frac{9}{4}$$
And so we have:
$$p_{n}=-\frac{3}{2}n-\frac{9}{4}$$
Now, by the principle of superposition, we have:
$$P_n=h_n+p_n=c_13^n-\frac{3}{2}n-\frac{9}{4}$$
Now we may determine the parameter $c_1$ from the given initial value:
$$P_0=c_1-\frac{9}{4}=0\,\therefore\,c_1=\frac{9}{4}$$
And we now have the solution satisfying the recurrence as:
$$P_n=\frac{9}{4}3^n-\frac{3}{2}n-\frac{9}{4}=\frac{3^{n+2}-6n-9}{4}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
