MHB W = F*dAnswer: Work Done by Force F on Cylinder Mass m1: 352.2 J
  • Thread starter Thread starter aarce
    Mechanics
The discussion focuses on calculating the work done by a force F on a cylinder resting on a board in a frictionless environment. Given the cylinder's mass of 30 kg, radius of 8 cm, and a pulling force of 44.15 N applied for two seconds, the work done is determined to be 352.2 J. The frictional force is calculated using the coefficient of friction of 0.1, which affects the net forces on both the cylinder and the board. The forum participants discuss the equations needed to analyze the forces and accelerations involved. The conversation emphasizes the importance of understanding the relationship between force, friction, and work in this scenario.
aarce
A cylinder of mass m1 = 30 kg and radius r = 8 cm lies on a board of mass m2 = 60 kg. The ground is frictionless and the coefficient of friction (both static and kinetic) between the board and the cylinder is u = 0.1. The centre of mass of the cylinder is pulled with a force of F = 44.15 for two seconds. Find the work done by force F.
Step 1: I drew a picture
Step 2: determined my knowns which is mass 1= 30 kg, radius = 8 cm, mass 2 = 60, u = 0.1, F= 44.15 for t = 2 sec.
Step 3: T.V.= F
Step 4: Equation: ?
Mathematics news on Phys.org
Step 3: T.V.= F
Step 4: Equation: ?
Hi aarce! Welcome to MHB! ;)
Let's start with the applicable equations.
The force of friction has a maximum of:
$$F_{f,max} = \mu F_n$$
where $F_n$ is the normal force given by:
$$F_n = m_1 \cdot g$$
The net forces on $m_1$ and $m_2$ are:
$$F_1 = F - F_f$$
$$F_2 = F_f$$
If we assume that the masses start sliding with respect to each other, we have that $F_f = F_{f,max}$.
What will be the respective accelerations then?
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
