-w8.3.9 int 1/(x^2 (1+x^2)) dx
  • MHB
  • Thread starter karush
  • Tags
    Dx
In summary, by using the expand function on the TI-Nspire, we can solve the integral $\int\frac{1 }{{x}^{2}\left(1+{x}^{2}\right)} \ dx$ by converting it into two simpler integrals: $\int\frac{1}{{x}^{2}}\ dx$ and $\int \frac{1}{{x}^{2}+1}dx$. By using the substitution $x=\tan{u}$, we can solve these integrals and get the final solution $-\arctan\left({x}\right)-\frac{1}{x}+C$.
karush
MHB
3,269
Whitman 8.3.9
$$\displaystyle
=-\arctan\left({x}\right)-\frac{1}{x}+C $$
Expand
$$\displaystyle
-\int \frac{1}{{x}^{2}+1}dx $$
Solving
$$\displaystyle
\int\frac{1}{{x}^{2}}\ dx =-\frac{1}{x}+C$$
Solving
$$x=\tan\left({u}\right) \ \ \ \ dx=\sec^2 \left({u}\right)\ du $$
$$\displaystyle -\int \frac{1}{{x}^{2}+1}dx
=-\int \frac{1}{\tan^2{u} +1}\sec^2 \left({u}\right)\ du
=\int 1 \ du
=u=-\arctan\left({x}\right)$$
Then...
$$\displaystyle -\arctan\left({x}\right)-\frac{1}{x}+C $$
You dropped a minus sign. Other than that it looks good.
karush said:
Whitman 8.3.9
$$\displaystyle
Expand
$$\displaystyle
I'm assuming you used Partial Fractions to do this...
Solving
$$\displaystyle
Solving
=\int 1 \ du
Then...
This is correct, well done :)
Actually I used the expand function on the TI-Nspire😎😎
Related to -w8.3.9 int 1/(x^2 (1+x^2)) dx
1. Can you explain the notation used in "-w8.3.9 int 1/(x^2 (1+x^2)) dx"?
The "-w8.3.9" indicates that this is a specific problem from a textbook or other source. "int" stands for integral, which is a mathematical operation representing the area under a curve. The expression "1/(x^2 (1+x^2))" is the integrand, or the function being integrated. "dx" represents the variable of integration, in this case, x.
2. What is the purpose of solving this integral?
The purpose of solving this integral is to find the value of the area under the curve represented by the given function. This can be useful in many areas of science, such as physics and engineering, where calculating areas and volumes is necessary for solving problems.
3. What is the step-by-step process for solving this integral?
The first step is to use algebraic manipulation to rewrite the integrand in a more manageable form. Then, we use techniques such as substitution, integration by parts, or partial fractions to solve the integral. Finally, we evaluate the integral using limits of integration, which are typically given in the problem.
4. Can this integral be solved analytically or does it require numerical methods?
This integral can be solved analytically since it is a definite integral with limits of integration. However, depending on the complexity of the integrand, it may be easier to use numerical methods such as the trapezoidal rule or Simpson's rule to approximate the value of the integral.
5. What are some real-world applications of this type of integral?
This type of integral has many real-world applications. For example, it can be used to calculate the work done by a variable force, the center of mass of an object, or the moment of inertia of a rotating body. It is also used in the field of economics to calculate consumer surplus and producer surplus. In physics, it is used to calculate electric potential energy and gravitational potential energy.
  • Calculus
  • Calculus
  • Calculus
