Walborn and FTL: Exploring Quantum Eraser with Double Slit
  • Thread starter UChr
  • Tags
    Ftl
In summary, Walborn's experiment demonstrates the standard Young interference pattern with the double slit placed in the path of photon s, and without the use of quarter-wave plates or POL1 at detector Dp. The experiment shows a correlation between the vertically and horizontally polarized photons, which can be explained through their momentum, time, and polarization correlation properties. However, this experiment does not provide any new or significant insights into physics or philosophy, as it can be decomposed into the mysteries of entanglement, the double slit, and phase change. A similar, almost classical experiment can be conducted using a light bulb and Nicol's prism, but it is too trivial to be awarded publication or grants. Additionally, the experiment does not result in a communication system
  • #36
Argh, I never should perform calculations by hand if PhD students asking questions rush in and out. The mm just vanished. Yes, right. However, then their claim that "Before the quantum eraser experiment was performed, Bell’s inequality tests were performed to verify that entangled states were being detected" becomes pretty pointless as the states are just polarization-entangled, but not at all momentum-entangled. So they do not need entangled photons besides for figures 7-9 where they have some boiled-down kind of delayed choice. At least unless you use 3d glasses.
Then I do not understand why they did not perform the experiment under incoherent circumstances. That experiment is much cooler. Maybe it is just a "publish or perish" issue, so they could publish two papers...
  • #37
Sure, they could use spatial/momentum entanglement, and use additional lens in p arm (such that 1/f = 1/lens-crystal + 1/lens-detector). Maybe that was a subject for next grant.
But such experiment is still equivalent to my "quantum eraser at home" - it does not really utilize entanglement Bell's mystery: it just uses it to select cases of some state in well defined fixed base.
Currently they use entanglement to select pairs (fixed-H,V). If utilising spatial entanglement they would just put additional condition to the trigger: (k=fixed value, k'=thus also fixed), while now k' is getting fixed by narrow focused pumping beam. Such experiment would be still essentially equivalent to the one with point-like source of polarised light.
  • #38
I tend to disagree. Using spatial entanglement under incoherent conditions means that you really need the information from the other arm to get the desired subset of photons in the double-slit arm.
In the setup used in the paper they could have placed the linear polarizer also in the double slit-arm and erase the which-way info there without having any need to use the twin photon. For spatial entanglement, there is no means to get the pattern without coincidence counting (unless you choose conditions where the light in that arm alone is already coherent, which, however, automatically breaks entanglement - that would be bogus).
  • #39
That's wahat I said - as you set the trigger in p arm to some transverse momentum (direction) you reject all cases with photons of direction differing from some fixed value in arm s. So such coincidence trigger is essentially equivalent to a pinhole in s arm installed just by the crystal.
I see those two cases quite similar:
- coincidence trigger on polarisation H in p is equivalent to V-polariser in s.
- coincidence trigger on direction in p is equivalent to pinhole (of the same angular size, as trigger detector) in s
The only difference is that it is impossible to modify spatial-entanglement/pinhole experiment further to "really delayed choice" - something like 3D-glasses do for polarisation.
  • #40
Ok, but this is a limited similarity. You would place the polarizer behind the double slit, but you would have to place the pinhole before the double slit which is effectively nothing else as breaking entanglement. There is still no means to get the pattern once the incoherent photon passed the double slit. That might sound like nitpicking, but I think the distinction is important (as you acknowledge in terms of delayed choice).
  • #41
Of course, you can't put a pinhole nor anything else behind slits to restore the pattern for spatially non-coherent light.
But that is not a delayed choice experiment! It is fully explainable in terms of common history.
Replace your spatially large crystal with a matrix of point-like pixels (display of your phone).
Now generate a random sequence of flashing pixels, only one pixel at a time. Don't note the sequence - it'll be recovered by measurements in p.
You have no pattern visible at s. But as you turn on coincidence trigger (p focused on just one pixel), you'll recover the pattern at s.
  • #42
Of course this is not yet a delayed choice experiment, but you can build one by expanding that setup.
  • #43
Walborn et al have a more approachable article entitled "Quantum Erasure" available at http://www.fsc.ufsc.br/~lucio/2003-07WalbornF.pdf" . It first appeared in American Scientist, and is targeted toward a technically literate audience, but leaves out the Dirac brackets.
They first describe the experiment without SPDC, i.e., with just a simple laser beam and a double slit. They get interference. Then, they insert the QWP's. Interference goes away. Then, they insert a polarizer between the qwp's and the screen, and interference comes back if it is at 0 or 90 degrees, but goes away if it's at + or - 45 degrees.
I think this is similar to one of XTS' experiments.
It's a good article, because they then show that if you then use entangled beams, and put the polarizer in the P beam and coincidence count, you get the same result.
One other note on XTS' experiment with the randomly oriented Nicol's prism:
xts said:
To deprive the experiment from mystery, try something similar, but (almost) classical:
Throw out the laser and BBO crystal, and put a light bulb in place of laser (very dim lightbulb, it should emit so little light that single photons should be distinguishable by our detectors) and Nicol's prism in place of crystal. Then made series of experiments: you turn prism to randomly chosen position of two such, that H polarised light goes to p and V to s or vice versa (don't note its position in the lab-book, that secret must be revealed by measurement in p!), then you turn on the lightbulb for a while (not too long, just to score a at least one click in both of p and s detectors, and note it as a coincidence event), then start again: choose randomly position...
The outcome of the experiment will be exatly the same, as of Walborn's.
Would you still say that 'measurement in arm p erases the which-path information in arm s' ?
But it is too trivial, so it won't probably be awarded by publication in Phys.Rev. nor by grant for next similar experiment.
Basically, he is saying that you randomly orient the prism, wait to get a count in both the p and s detectors, then repeat. What this means is that the P photon basically records the polarization of the S photon (one came out of the ordinary beam, the other from the extraordinary beam, since Nicol's prism is a polarizing beam splitter). So, if you put a horizontal polarizer in the P beam and detect a photon there, then XTS assumes the corresponding photon in the S beam would be vertically polarized, and so you would get interference. I believe that this assumption is flawed, because the S and P photons were polarized in specific orthogonal angles by the pbs, and will not have perfectly correlated results if tested with other polarization angles.
PS - sorry to come into this so late, but I've been away from the forum for a while, and I had to reread all of the articles to sort of catch up again. Thanks for your discussions in this thread, it really stimulated me to think this stuff through again from a fresh point of view.
  • #44
...if you put a horizontal polarizer in the P beam and detect a photon there, then XTS assumes the corresponding photon in the S beam would be vertically polarized, and so you would get interference. I believe that this assumption is flawed, because the S and P photons were polarized in specific orthogonal angles by the pbs, and will not have perfectly correlated results if tested with other polarization angles.
It is not flawed in context of Walborn's experiment setup - he never measures their polarisation in a rotated base - other than H/V. Only what he takes from "entanglement mystery" is a source of mixed (H/V) and (V/H) pairs, of which those in eigenstate (H/V) are selected by coincidence trigger.
I never claimed that Bell was wrong... (just contrary) But this experiment has nothing in common with it.
My Occamian point is that people like Walborn tend to use high pitch rethorics of 'quantum erasure' where simple 19th-century wave optics is sufficient to explain the experiment.
PS.
I just received my QWP (ordered few days ago), and my 18 years old nephew is comming back from his holidays, so we are ready to build our Quantum Eraser at Home...
  • #45
Actually, after additional reflection, I think the xts experiment will work. If the Nicol's prism PBS is oriented at 90 degrees, then the P beam will be polarized horizontally, so it will be detected through a horizontal polarizer, and the S photon will be 90 degrees and the QWP's will not mess up its interference pattern. As the PBS angle moves away from 90 degrees, the probability P will be detected declines. If the PBS angle is 45 degrees, then the S photons will be non-interfering, but only 50% of the P photons will register, so the fringes should still be visible above the noise. And, when the angle goes to 90 degrees, none of the P photons will register, so none of the anti-fringe S photons will register, so the anti-fringes will not mess up the fringes. So, the interference pattern will be less dramatic, but I believe it will appear.
I basically agree. I'd say that Walborn's using the polarizer on the P beam to detect photons which will be (or have been) all phase shifted the same way by the qwp's, so that subset can show interference. In this sense it doesn't matter if the P photons are detected before the QWP's affect the beam, or afterwards.
One complication, however, is that in QM the polarization of the S photons is not defined when they go through the QWP's (Bell's theorem, no 'hidden variables'). The polarization is not defined until it's detected, which happens when the P photons go though the filter and get detected. So in this sense, it's hard to reconcile the classical optics version with the QM version.
PS.
Looking forward to hearing about the results.
  • #46
In my QE@H you have the same - even more delayed choice, than in Walborn's!
Actually, mathematics is also the same as in QM - photon is a wavelet whos polarisation may be described as a complex superposition of H and V waves, which is unknown and gets defined not earlier than when I see it either with left (H) or right (V) eye, after reflecting from the screen
To remind the setup: QE@H consists of incoherent pointlike source, double slit with QWPs (oriented H behind one slit, V behind another), polarisation preserving screen and polarisation (linear, H/V) glasses to watch the result.
Walborn-like story is that photons come through slits with they polarisation marked by QWP, so no pattern is visible. But if you (very quickly!) put your glasses on, you are acting backward in time (as the marked photons already passed QWP and slits, and maybe even got reflected from the screen), erasing that information.
  • #47
So QE@H is the same as the first setup in the Walborn paper at http://www.fsc.ufsc.br/~lucio/2003-07WalbornF.pdf :
laser->double slit->QWP->H polarizer-> screen
(except they use a laser, and you polarize after the screen).
I'm not sure you'll get interference if the source is not coherent, but if you play around with the source enough then you should get the same results they get: fringes viewed in one eye, and anti-fringes in the other eye. It sounds like you might be using a video projector setup, which is actually a nice repurposing of some home theater equipment.
I was thinking more about your other version, where a randomly oriented PBS creates S and P beams which are not entangled but are orthogonally polarized. In that one, you say that you will wait until you get a detection at S and P. I'm assuming there's a H polarizer in the P beam before the detector. In this case, there are orientations of the PBS which will result in nearly zero passage of P photons through the polarizer, so you could end up waiting a nearly infinite time for detection of a P photon. So in that version of the experiment you would obtain best results if you only leave the detectors on for a short period of time, and then re-randomize the PBS orientation if you do not detect a P photon within deltaT.
  • #48
I am also curious to hear about xts succeed.
Meanwhile, a commentary on QWP in Walborns setup:
After the two QWP’s are passed, the two paths are circularly polarized Right = R or Left = L.
This gives 4 possible outcomes:Path1,Path2= R,L OR L,R OR R,R OR L,L.
If we put a mirror immediately after the QWP's and send the two ‘paths’ return we get:
R,L returns as (+/-) H, (+/-) H = Horizontal polarized.
L,R returns as (+/-) V, (+/-) V = Vertical polarized.
R,R and L,L returns as (+/-) H, (+/-) V OR (+/-) V, (+/-) H = polarized +45 (H + V) or -45 degrees (H – V).
This suggests that QWP start to polarize linearly in 4 combinations: H H or V V or V H or H V and then a little later circularly polarizes.
The linear polarization entanglement then stops and sets p-photon as linearly polarized perpendicular to one of the 4 polarizations.
Sounds fairly reasonable?  
