intermu
- 2
The typical walking speed of a person walking at a relaxed pace can be estimated by modelling their legs as a physical pendulum. Assume that the length of a person's leg is L and it pivots about the hip and the leg is tapered (more mass towards the hip and less towards the foot). So that its rotational inertia of the leg is 1/6 MR2
a) Determine the frequency of the oscillations of the leg
b) Derive a formula for the walking speed based on the frequency and the maximum angle of the oscillation
c) What is the walking speed of a person whose legs are 1m long with a center of mass at 0.45m away from the hip who is walking so the maximum angle of their legs is 30deg away from the vertical?
a) w = sqrt (mgl / I)
Where w = oscillation frequency, m = mass, g = acc due to g, l = length, I = rotational inertia
b) v = -Aw sin(wt+theta)
where A = amplitude.
From the equation at a), w = sqrt (MgL / (1/6) ML2)
w = sqrt (6g / L)
for b), I would have thought to use the formula as I stated in b), but since the example said to use the frequency and the maximum angle, I'm not sure which formula to use.
I thought about using the equivalent of the formula v = u + at, but I don't have the angular acceleration with me. I also briefly thought to use angular momentum to find the angular velocity before converting it to linear velocity but it seems far-fetched.
I also had thought to use a differential equation going by Torque = Ia, where I = rotational inertia and a = angular acc, and equating it to torque = mgl. Then thus, having:
MgL = 1/6 ML^2 a,
6g = aL
a = 6g/L
But I have no idea how that ties in with the question.
I suppose I have the period by playing around with w = 2pi f, turning into w = 2pi / T.
If someone could help, it will be much appreciated. Thank you :)
