Wall Cavity Insulation Question?
In summary: They are asking you to find the thermal conductivity of the four materials. You use the thermal conductivity data to find the thickness that needs to be added to a brick wall in order to achieve the same thermal resistance as a cavity concrete block wall.
jake96
33
Hi guys, I have read this question over and over and have no idea where to start, would anyone be able to help.
The Question
Up to 20% of all heat lost in domestic dwellings occurs through walls. Many modern Australian homes are built by constructing walls using ‘cavity concrete blocks’ which have at least a 75 mm air gap or ‘cavity’ as part of their design.
Consider a home built using cavity concrete blocks and compare this to using two other construction materials; brick and aluminium siding. By investigating the heat flow through an external wall,
a) outline the range of assumptions you make.
b) determine, using appropriate calculations to support your answer, the required equivalent
thickness of a home's wall, in order to give the same amount of insulation as a cavity concrete
block wall if the wall is made of
i) brick.
ii) aluminium siding.
c) Discuss comparisons between the individual construction materials.
Thanks
no idea
don't know where to start
They are asking you to compare the thermal performance of three different wall constructions.
Cavity block
Solid Brick
Aluminum (I'm not familiar with this type).
How about you start by calculating the thermal resistance of a cavity concrete block wall ? They are made up of a sandwich of concrete block - air - concrete block. Should be possible to find the data you need (eg typical thickness of each layer and thermal resistance of each material).
ok, I've found the thermal conductivity of the four materials
air: 0.024
Aluminium: 205
Brick: 0.15
Concrete: 0.55
and found thickness for concrete block (in accordance to pictures from homework sheet)
concrete (30mm)-air (75mm)- concrete (30mm)
would this be the resistance of the cavity concrete block?
=.03/.55+.075/.024+.03/.55 (thickness/conductivity)
=3.234Km^2/W
also using a wall of 1mx1m so its not a hassle in calculations
air: 0.024
Aluminium: 205
Brick: 0.15
Concrete: 0.55
=3.234Km^2/W
Good. Now, how thick would these other individual materials have to be to give this same resistance?
Chet
Brick
3.234=x/.15
=485mm
aluminium
3.234=x/205
=663m
this seems a little extreme for the aluminium
jake96 said:
Brick
3.234=x/.15
=485mm
aluminium
3.234=x/205
=663m
Well, aluminum has a very high thermal conductivity.
Chet
so these sort of calculations would be correct considering no other outside influence,
in reality this value would be much lower due to reflection and other attributes
What kind of reflection is involved with heat conduction?
Chet
What formula did you use to find the thermal conductivity?
Related to Wall Cavity Insulation Question?
1. What is wall cavity insulation?
Wall cavity insulation is a type of insulation that is installed in the space between the inner and outer walls of a building. It helps to reduce heat loss and improve energy efficiency in homes and buildings.
2. How does wall cavity insulation work?
Wall cavity insulation works by creating an air barrier between the inner and outer walls of a building. This barrier helps to prevent the transfer of heat from the inside of the building to the outside, keeping the building warmer in the winter and cooler in the summer.
3. What are the benefits of wall cavity insulation?
Some of the benefits of wall cavity insulation include improved energy efficiency, lower energy bills, and increased comfort in the home or building. It can also help to reduce outside noise and improve the overall indoor air quality.
4. How is wall cavity insulation installed?
Wall cavity insulation is typically installed by a professional contractor who will use specialized tools to inject the insulation into the wall cavity. It can also be installed during the construction of a new building.
5. Is wall cavity insulation safe?
Yes, wall cavity insulation is generally considered safe. It is made from materials such as fiberglass, mineral wool, or foam, which are non-toxic and non-hazardous. However, it is important to follow proper safety precautions during installation to avoid any potential hazards.
  • Materials and Chemical Engineering
18K
