Watch problems gaining and losing time
In summary: If you watch gains 3 minutes in 2 hours, it gains 3*12=36 minutes in a day. So it can't show the correct time after only two days.Try to write the time on your watch as a function of the correct time.Say ##W(t)=## some function of the correct time ##t## (expressed in minutes)Then for your clock to again show the correct time, you should have ##W(t)=t+720## (because there are 720 minutes in 12 hours, and your clock has to gain 12 hours to again show the correct time). Solve that equation for ##t##.With this information, Mrs Varma's watch should next
  • #36
Can anyone just explain to me by doing it? As I have tried time and time again (proof in my threads)... But simply don't get it?
  • #37
He did NOT ask how much time must elapse so that the watches read the same time again. He asked how far apart they must be relative to each other when they display the same thing.
  • #38
Natasha1 said:
Yes and this is what I answered...
After (in hours) Mrs Varma's watch My watch
1 2.5 1.5
2 5 3
3 7.5 4.5
4 10 6
5 12.5 7.5
6 15 9
7 17.5 10.5
8 20 12
9 22.5 13.5
10 25 15
11 27.5 16.5
12 30 18
13 32.5 19.5
14 35 21
15 37.5 22.5So after 15hrs or 3am on 2nd January will our two watches show the same time.
After 15 hours the difference is 60 minutes, or 1 hour. But these are 12 hour watches, not 1 hour watches. That's why they don't show the same time after 15 hours.
Natasha1 said:
This is too hard for me... I'm lost.
720 (not sure why but there you go) / 96 = 7.5 days so the answer would be 9th January at midnight
Yes, the 7.5 days is correct.
Why?
Well, you know that the difference between the two watches grows by 96 minutes a day.
What does it mean that the difference between the two watches is 96 minutes (1 hour and 36 minutes)? It means that if your watch is (hypothetically) at 12.00 noon, Mr Varma's watch will be 96 minutes behind, that is 10.24 am.
After two days the difference between the two watches is 192 minutes (3 hours and 12 minutes). It means that if your watch is (hypothetically) at 12.00 noon, Mr Varma's watch will be 192 minutes behind, that is 8.48 am.
And so on.
When will the two watches again show the same time? Well, when the difference between them will have gone full circle, meaning 12 hours.
12 hours = 720 minutes. When the difference is 12 hours, the watches again show the same time, precisely because these are 12 hour watches.
That's why you divided 720 by 96 to get the correct result.
  • #39
Natasha1 said:
How on Earth do I work out 3?
You already established in the first question that your watch will again show the correct time after 20 days.
That means it will also show the correct time after 20+20=40 days. And also after 40+20=60 days. And so on.
Now, before solving 3, try to establish after how many days Mrs Varma's watch will again show the correct time. This is similar to the first exercise.
  • #40
Does that mean that Mrs Varma's watch which loses 5mins every 2 hours then loses 60 mins in 12 hours(or 720 mins)
So Mrs Varma's watch will show the correct time in 720/60 = 12 days and because my watch in 720/36 = 20 days they will both show the correct time in
60 days as this is the lowest common multiple.
Is this correct?
  • #41
Is this correct?
Yes.
  • #42
Thank you :)
  • #43
Answers
1. Gained time = 12 hours = 720 min
After t hours
t×3/120 = 12
t=480 hours=20 days
Jan 21 St at noon
2. To show same time, time gained in one watch should be equal to 12 hours minus time lost in other watch. It can even be vice versa.
Time gained = 12 - time lost
t * 3/120 = 12 - t* 5/120
t = 240 hours = 10 days
Jan 11 at noon
3 . the clocks show same time every 10 days
The clock shows right time after 20 days ( from problem 1)
Hence both clocks show correct same time after 20 days
Jan 21 at noon
  • #44
dgsspkumar said:
Answers
After t hours
t×3/120 = 12
t=480 hours=20 days
Jan 21 St at noon
Correct.
Jan 11 at noon
t * 3/120 = 12 - t* 5/120 is correct, but then you made a computation error.
Jan 21 at noon
Not correct, as based on wrong result for 2).
  • #45
After t hours
t×3/120 = 12 t=480 hours=20 days
Jan 21 St at noon
t = 180 hours = 7days 12 hours
Jan 8 mid night
3. The clocks show same time every 7days 12 hours.
The 1 st clock shows right time after 20 days ( from problem 1)
The answer is a common multiple of 7.5 and 20.
60 days
Hence Clocks show correct same time after sixty days
jan 1 to jan 31 - 30 days
feb 1 to feb 28 - 28 days
jan 1 and jan 2
hence answer is Jan 2 noon
Reference https://www.physicsforums.com/threads/watch-problems-gaining-and-losing-time.846247/page-3
  • #46
Samy_A said:
Correct.
After t hours
Jan 21 St at noon
Jan 8 mid night
60 days
jan 1 and jan 2
Is this correct now ?
  • #47
After t hours
Jan 21 St at noon
Jan 8 mid night
60 days
jan 1 and jan 2
Yes.
(I mean the sixty days for 3. You probably made a typo at the end, where you meant March and not January.)
  • #48
Samy_A said:
Yes.
Ya it was march 2 noon.
