maxx_payne
- 86
hello guys
how can i have liquid water at 120 c ?
You're going to have to go into a lot more detail about what you are trying to do if you want us to be able to help you. Could you draw/post a diagram of the system you are trying to build?maxx_payne said:so tell me how can i make a system from
1- pump
2- heater
maxx_payne said:ok guys i will explain my idea to you
now at my work i have a machine that's used to push the fusible pvc on some aluminium materials , and this aluminium is heated to a temp above 100 c
so pvc needs heat more than 100 and less than 140 to ensure that pvc will stuck on the alominium
and that's is done using a small machine which gives water at 130 or 120 to give the required heat to the pvc aluminium pieces
so all i want to do now is understanding how this unit work ?
it consists of many thermostatic valves , 2 electric heaters , water pump and many connections
so the main problem to me is how to make water pressurized ??
if the pump pumps water to the tank which contain the heater the water will be discharged at atm pressure how can i pressurized water /?
Yes, liquid water can exist at 120°C under certain conditions. At sea level, water typically boils at 100°C, but at higher altitudes where atmospheric pressure is lower, water can boil at higher temperatures. Additionally, if the water is under high pressure, it can remain in liquid form at higher temperatures.
The maximum temperature at which liquid water can exist is about 374°C, which is known as the critical point. At this point, the liquid and gas phases of water are indistinguishable, and the substance is known as a supercritical fluid.
Impurities, such as salt or other dissolved substances, can raise the boiling point of water. This is because the presence of impurities disrupts the intermolecular forces between water molecules, making it harder for them to escape into the gas phase.
No, liquid water cannot exist at 120°C in a vacuum. In a vacuum, there is no atmospheric pressure to keep the water molecules together in liquid form, so the water will immediately boil and turn into gas at any temperature above its boiling point of 100°C.
In addition to pressure and impurities, other factors that can affect the boiling point of water include the type of container it is heated in, the altitude, and the presence of nucleation sites (such as scratches on the container's surface) which can make it easier for water to boil at lower temperatures.
