Water Bottle illuminates partly hidden image
In summary: Magnification is when you increase the size of an object by using a lens or other device. In this case, the water bottle magnifies the view of the clouds outside.
Feather17
At work, I have my plastic cheap blinds shut in the orientation of siding on a house. My office is only lit by a lamp. Outside is a sunny day. From my view, directly infront of the window, sitting down, facing north, around mid to late day is of vauge reminisce of clouds in the blue strips of light that gets throught the blinds.
But when I hold my empty plastic water bottle up to my eye, I can see the clouds outside drastically better! I have pictures on my phone of this but don't know how to upload them on here. Anyways, does anyone know what's going on, and why this works?
My observations are that:
1. the orieniation of the water bottle does not effect anything.
2. reversing the blinds the same effect is seen except down low at the cars in the lower half of the window where light gets through that reaches the eyes.
3. Water bottles have slight magnification it appears.
I googled magnification some and I think that is where the answer is.
What does 'better' mean in this context? Brighter? Larger? Clearer?
Your field of view is decreased. You are looking at a magnified portion of your original view. A magnifying glass would literally do the same thing
Sounds like good old magnification!
Better as in improved quality, more information. I could claim the cloud looks like something where as before you cloud barely make a claim a cloud was there. It doesn't not appear larger or brighter to the naked eye just you can get more information.
Yes. Thanks for reply. I looked up how magnifying glass works. And I do think the Rays are less diverged and more parallel so the light from outside has more detail due to the eye not having to strain to focus.
I wonder if you're getting a small aperature effect.
Are you near-sighted?
Yes. But I took a photo of it and it show up great. Every body I told when I got home blew me off until I showed them the picture then they were like wow.
You could upload the photo here.
FAQ: Water Bottle illuminates partly hidden image
What is a Water Bottle illuminates partly hidden image?
A Water Bottle illuminates partly hidden image is a scientific phenomenon where a partially hidden image or text on a water bottle becomes visible when a light source is shined through the bottle.
How does the water bottle illuminate the hidden image?
The water bottle acts as a lens, bending the light that passes through it. This bending of light causes the image or text to become visible, similar to how a magnifying glass works.
What causes the hidden image to appear on the water bottle?
The hidden image on the water bottle is created during the manufacturing process. The bottle is heated and compressed, causing the plastic to stretch and create a thin, transparent layer. This layer is then imprinted with the image or text, which becomes visible when light passes through it.
Can any water bottle be used to create this effect?
No, not all water bottles will have this effect. The water bottle must have a certain level of transparency and a smooth, curved surface to act as a lens for the hidden image to be visible.
Is the hidden image permanent?
The hidden image on the water bottle is typically permanent, as it is created during the manufacturing process. However, over time and with wear and tear, the image may become less visible or distorted.
10K
