Water electricity pump, given efficiency percentage?
In summary, changing the potential energy of water is a common method of storing excess renewable energy. In this process, a 10 kg mass of water is raised 10 m using an electrically-powered pump with 62% efficiency. The water then flows back down and passes through an electricity-generating device with 84% efficiency. The overall efficiency of the process can be calculated by multiplying the individual efficiencies, resulting in 52.08% of the electricity originally used to pump the water being recovered.
Allison Barry
Changing the potential energy of water is frequently used as a means of storing excess renewable energy when it is not needed and using it when it is needed. An electrically-powered pump with efficiency 62 % raises a 10 kg mass of water a height of 10 m. The water is subsequently allowed to return to its original elevation while passing through an electricity-generating device with efficiency 84 %. Calculate the percentage of the electricity originally used to pump the water that is recovered by the entire process.
I haven't a clue where to begin, this is energy systems engineering. Would you derive an equation for the electric pump and then the electricity generator? In need of serious guidance
Start by asking yourself how much energy does it take to raise 10 kg of water by a height of 10 m. Apply the efficiency figure for the electric pump to this amount of energy to see what the pump must furnish.
You can do what steamking said but the question can be answered without calculating the power needed to raise the water...
If you have any two machines connected together and one is 62% efficient and the other is 84% efficient what is the efficiency of the two combined? Perhaps draw a block diagram and remind yourself what "efficiency" actually means in terms of the inputs and outputs.
Related to Water electricity pump, given efficiency percentage?
1. How does a water electricity pump work?
A water electricity pump works by using an electric motor to drive a pump that pushes the water through a system of pipes and valves. The pump creates a pressure difference that allows the water to flow from a lower to a higher level, providing a source of energy that can be harnessed for various purposes.
2. What is the efficiency percentage of a water electricity pump?
The efficiency percentage of a water electricity pump refers to the ratio of the energy output to the energy input. It is typically expressed as a percentage, with higher percentages indicating a more efficient pump. The efficiency of a water electricity pump can vary depending on factors such as the design, maintenance, and operating conditions.
3. How is the efficiency percentage of a water electricity pump calculated?
The efficiency percentage of a water electricity pump is calculated by dividing the energy output (such as the power generated) by the energy input (such as the power consumed by the electric motor) and then multiplying by 100 to get a percentage. This calculation can be affected by various factors, so it is important to use accurate and standardized measurements.
4. What is a good efficiency percentage for a water electricity pump?
A good efficiency percentage for a water electricity pump can vary depending on the specific application and industry standards. Generally, a pump with an efficiency percentage of 70% or higher is considered to be efficient and can help reduce energy costs and environmental impacts. However, some pumps can achieve even higher efficiencies, depending on the design and operating conditions.
5. How can the efficiency percentage of a water electricity pump be improved?
The efficiency percentage of a water electricity pump can be improved by implementing various measures such as regular maintenance, proper sizing and selection of the pump, and using energy-efficient components. Additionally, advancements in pump technology and design can also contribute to improving the efficiency percentage. It is important to regularly monitor and assess the efficiency of the pump to identify areas for improvement.
  • Electrical Engineering
  • Mechanical Engineering
