Water Filling a Cylindrical Container with a Scale Under It
So the applied force on the container is just the weight of the column of water that has been falling, regardless of how much has hit the surface already?Yes, that's correct. Because the weight of the water is always acting downwards, regardless of whether it has hit the surface or not. It's the same concept as when you're carrying a bucket of water and you feel the weight of the water pushing down on your hand, even though the water hasn't spilled out yet.
yellowcakepie
A scale is adjusted so that when a large, shallow pan is placed on it, it reads zero. A water faucet at height h = 4.0 m above is turned on and water falls into the pan at a rate R = 0.20 kg/s.
A) Determine a formula for the scale reading as a function of time t if at the moment t=0 first drops of water reach the pan.
B) Determine the reading for t = 9.4 s.
C) Repeat part B, but replace the shallow pan with a tall, narrow cylindrical container of area A = 18 cm^2 (the level rises in this case).
Δx = 0.5gt^2
v = gt
I = R*v
F(t) = I + Rgt
I have already solved parts A and B, but I am having trouble with part C.
A) F(t) = R√(2h/g)*g + Rgt (force due to change of momentum of the water plus weight of water in the container)
B) F(9.4 s) = 20 N
C) I have A = 0.0018 m^2 area for the cylindrical container, and density of water (D) is 1000 kg/m^3, so I got the fill rate by dividing D/R, and then divided A by D/R to get the change in height per second, which is 0.11 m/s.
I have no clue how to incorporate this height change rate into my answer.
The height difference between faucet and water level will change, but at the same time, you have to consider that the container fills a bit faster than you estimated because the stream of water represents a volume that is filled already. There is an argument that avoids explicit calculations of these effects.
It looks like the teacher didn’t think of the second effect when making this problem.
The pan is said to be "large and shallow". I think that means that the linear parameter(s) defining the area (the radius if the pan is circular) are much larger than its height. I would interpret that to mean "ignore the height change of the level in the pan."
The question is about part C, where the container is not shallow any more.
I didn't quite understand what you meant when you said "the stream of water represents a volume that is filled already".
I just need to calculate the force reading of the scale at 9.4 seconds after the first drop of water has hit the bottom of the container and started filling up.
As it fills up, I'd imagine the water would hit the surface quicker and quicker. But I don't know how to represent that in a mathematical equation.
The shaded area in this very shady sketch:
yellowcakepie said:
R√(2h/g)*g
(from A)
Can you interpret this physically in relation to the amount of water falling down?
mfb said:
(from A)
Yes, that is the force exerted on the container by the falling water when it hits the container. It is dependent on mass flow rate R, and the velocity of water upon impact, which depends on the time it takes to fall the distance between the faucet and surface of the water. I got the rate of change in height already (0.111 m/s). The time (t) it takes to hit the surface of water is then:
h - 0.111t = 1/2gt^2
t = 0.892 s
This is slightly different from what I got in part A (0.904 s) though...
Looks like the difference betweeen 9.81 and 10 m/s^2.
No, that's not what I meant. If you multiply the mass flow rate by the time it takes the water to fall down, you get a quantity of water. Where can you find this quantity of water in the setup?
How can you relate this quantity to the force you found for (A)?
That quantity of water would be the column of water falling down to hit the surface, which is just anywhere inside the container, above the rising water level.
That quantity of water is R*t, so with an empty container, would be 0.20 kg/s * 0.904 s = 0.1808 kg (using the time for water to hit in part A). The weight of water would be 1.77 N.
But this force would decrease as the water level in the container rises, since less time is needed to travel a smaller distance. Distance (d) is d = h - 0.111t.
h - 0.111t = 1/2gt^2 (to calculate time, right?)
The key point here: It is the total amount of water falling at a given point. And its force is the weight of this water.
For the problem here it doesn't matter if water arrived at the bottom already or not, as long as the stream started hitting the container.
Why is that the case? This concept seems physics-defying...
It only applies to a steady flow rate. If you would suddenly stop the water flow it wouldn’t be true any more of course.
Imagine a larger system where the faucet and a second tank are on the scale as well. While the water is flowing down at a constant rate, the center of mass moves downwards at a constant velocity. Based on conservation of momentum, whst the scale shows has to be the total mass of the system - including the water that is in free fall. The additional force at the bottom to stop the water is precisely the weight of the water in free fall.
Likes yellowcakepie
Oh, so turns out I just had to plug in the changing height (h - 0.111t) into the h term inside the square root and plug in t = 9.4s. And the resulting force is exactly the same as if the container was large and shallow, which is 20 N, because of the effect that you described. Thank you for the help.
Likes mfb
Related to Water Filling a Cylindrical Container with a Scale Under It
1. How does filling a cylindrical container with water affect the reading on a scale placed under it?
When water is added to a cylindrical container, the scale placed under it will show an increase in weight. This is because the weight of the water is being added to the weight of the container, resulting in a higher overall weight.
2. Why is a cylindrical container used in this experiment instead of a different shape?
A cylindrical shape is used because it allows for more accurate measurements of volume and weight. The volume of a cylinder can be easily calculated using its height and radius, and the weight of the water can be evenly distributed in the container, providing a more consistent reading on the scale.
3. Does the thickness of the container have an impact on the results?
Yes, the thickness of the container can affect the results. A thicker container will add more weight to the overall measurement, so it is important to use a container with a consistent thickness for accurate results.
4. Can the experiment be performed with different liquids besides water?
Yes, this experiment can be performed with different liquids as long as they have a consistent density. This means that the weight of the liquid per unit volume must be the same for accurate results.
5. How is the water level in the container measured?
The water level in the container can be measured by using a ruler or measuring tape to determine the height of the water. Alternatively, a marked measuring cup or graduated cylinder can also be used to measure the volume of water added to the container.
