Water gun problem, pump stroke -> pressure
In summary: Vi+nfRfTf)))In summary, the hand pump stroke length, and the diameter of the pipe the pump is inside, can be used to calculate how much pressure gets built up in the guns pressure chamber.
CollegeStudent
109
Hello all, I have a question about a water gun problem I'm working on.
The general question is...how can you associate the hand pump stroke length, and the diameter of the pipe the pump is inside, with how much pressure gets built up in the guns pressure chamber?
You can't without knowing the volume of the pressure chamber, obvious a larger pressure tank will tank more pumps to get up to a certain pressure.
Once you know tank volume then you can find the increase in tank pressure from each stroke from the ideal gas law.
https://en.wikipedia.org/wiki/Ideal_gas_law
Each stroke adds the mass of air (at atmospheric pressure & temp) found in the piston volume.
Alright, so let's see...lets take this animation for example: http://static.howstuffworks.com/flash/water-blaster-soaker.swf
****Only difference will be that originally the only water will be in the reservoir, nothing in the system****
Lets say the stroke length is 11 [in.] and the cylinder the piston is moving within has a diameter of 2 [in.]. Also we'll assume the volume of the pressure chamber is 250 [in^3]
*All general numbers*
The first out-stroke opens the first valve allowing water to fill that volume...the in-stroke would then input a mass of water equal to [itex]\pi \times (2 [in.])^2 \times 11 [in.] = 44 \pi [in.]^3 = 2265.17501 [g][/itex] directly into the pressure chamber? Am I saying that correctly?
Ha, obviously I would need to change the volume of the chamber...that's what I get for choosing random numbers!
Okay let's instead say the Volume of the Pressure Chamber is 5000 in^3 *again just choosing random numbers, as I know this is unrealistic for this application.
This is where I get a bit confused, the ideal gas law states [itex] P = \frac{mRT}{V} [/itex]
The original pressure in the chamber would be [itex] P = \frac{mRT}{V} = \frac{(\rho \times V)RT}{V} [/itex] so that would cancel out the Volume? Since I seem to be going in a circle, I'll just wait for clarification
Ok, I assumed the piston pumped air in, not water. In that case, seeing as water is incompressible the volume of the pressure chamber is effectively reduced by the volume of the piston with each stroke. The corresponding increase in chamber pressure will depend on the ratio of the chamber volume to the piston volume.
Got it, so to work with a general example... let's say the volume of the chamber is 5000in^3 originally when filled with just air.
The *cylindrical* piston has an 11 [in] stroke and we'll say a 2 [in] diameter...so the volume would be that same 2265 in^3
This volume would effectively be moved into the pressure chamber after each stroke.
So to find the pressure in the chamber after the first stroke,we are worried about the volume of air remaining in the tank? So (5000-2265) is the new volume of the tank? And we would use that to calculate the pressure?
For example *forgive me, on my phone* P = (mass of water * temp * R)/volume of air remaining in the tank?
This is probably incorrect as you stated it would depend on the ratio of volumes...so knowing the ratio is roughly 2.2...where do we go from there?
I appreciate your time by the way! Never knew a squirt gun could stump me so badly!
I think we can assume it's an isothermal process as I would expect the thin walls and the presence of the water would allow good heat transfer so the compressed air temp. does not rise above the ambient temp.
So we have two states, initial and final
PiVi =niRiTi
PfVf =nfRfTf
and the number of moles, gas constant and temperature are the same for both states so:
niRiTi = nfRfTf
and so
PiVi = PfVf
(which is Boyle's Law)
And solving for final pressure:
Pf = Pi (Vi / Vf)
PiVi =niRiTi
PfVf =nfRfTf
niRiTi = nfRfTf
and so
PiVi = PfVf
Pf = Pi (Vi / Vf)
Perfect, and that would be the pressure built up in the chamber after corresponding pumps
Now, if I wanted to find the velocity of water leaving the nozzle when the trigger is pushed...since I know the pressure in the chamber, I could set up a Bernoulli relation correct?
[itex] \frac{P_{nozzle}}{\rho} + \frac{V_{1}^2}{2} + gz_{1} = \frac{P_{chamber}}{\rho} + \frac{V_{2}^2}{2} + gz_{2} [/itex]
Where we know:
> V_2 is 0
> We can now find P_chamber using Boyles law above
> P_1 is atmospehric pressure
Am I correct in this regard?
Where we know:
> V_2 is 0
Yes, as a first order approximation.
Any real water gun has losses, the pump is not 100% efficient and there are major & minor losses throughout the system. At a random guess, I'd say only 50%-80% of the work done on the pump handle is converted to kinetic energy of the outgoing water.
Absolutely! And I do plan on having this losses accounted for!
Major head losses = [itex] h_{l} = f \frac{L}{D} \frac{V^2}{2} [/itex]
Where 'f' is the friction factor found via the Reynolds number and the roughness
Minor head losses = [itex] h_{ml} = k \frac{V^2}{2} [/itex] where k will depend on the bends in the system and other geometric factors etc
So I could always modify Bernoulli's and say:
[itex] (\frac{P_{atm}}{\rho_{air}} + \frac{V_{1}^2}{2} + gz_{1}) - (\frac{P_{chamber}}{\rho_{water}} + \frac{V_{2}^2}{2} + gz_{2}) = f \frac{L}{D} \frac{V^2}{2} + \sum k \frac{V^2}{2} [/itex]
I can use my textbook to find:
>the roughness for certain materials
>friction factor (moody chart)
>minor loss coefficients for the various bends
So with all that, I believe I can solve for the true velocity of the water leaving the nozzle correct?
Hmm, although, the Reynolds number...
[itex] Re = \frac{VD}{v} [/itex]
since I need the velocity FOR the Reynolds number...maybe it isn't quite as easy as I am thinking?
Hey billy_joule, Sorry to bother you again, but any more insight on this?
While before, we could have calculated the velocity leaving the nozzle *ignoring losses*
Now, taking into account the losses, we have 2 more terms both requiring a velocity [itex]h_{l} = f \frac{L}{D} \frac{V^2 }{2}[/itex] and [itex]h_{ml} = k \frac{V^2}{2}[/itex]
I'm confused on how to find the friction factor here, as it is a function of Reynolds Number which involves the velocity.
At this point, should I guess a friction factor *assume the flow is turbulent* and iterate until I get a consistent value for V?
It looks like you're on the right track.
Yes, iteration is how I learned to solve these sorts of problems.
Perfect! Also, 1 LAST question that comes from the Boyle's Law relation we came up with earlier
[itex]P_{f} = P_{i}\frac{V_i}{V_f}[/itex]
Finding the initial pressure inside of the pressure chamber, using the ideal gas law, leads to [itex]P_{i} = \frac{mRT}{V}[/itex] Which, when replacing [itex]m = \rho V[/itex] leads to [itex]P_{i} = \rho R T[/itex]
I'm just confused here, as the volume of the tank should DEFINITELY play a factor in this shouldn't it?
Oh man...That was just a blonde moment...it took me actually calculating it out to see that it is just atmospheric pressure. That was fun haha!
Related to Water gun problem, pump stroke -> pressure
1. How does a water gun work?
A water gun works by using a pump to create pressure in a small chamber. When the trigger is pulled, the pressurized water is released through a nozzle, creating a stream of water.
2. What is the relationship between pump stroke and pressure in a water gun?
The longer and harder the pump stroke, the higher the pressure will be in the water gun. This is because more force is being applied to the water, compressing it and increasing its pressure.
3. How does the size of the nozzle affect the pressure in a water gun?
The size of the nozzle does not directly affect the pressure in a water gun. However, a smaller nozzle will result in a higher velocity of water coming out, creating a more powerful stream.
4. Can the pressure in a water gun be too high?
Yes, the pressure in a water gun can be too high, which can result in the gun breaking or the stream of water being too powerful and potentially causing injury. It is important to use caution when pumping a water gun and not over-pump it.
5. How does the type of pump used affect the pressure in a water gun?
The type of pump used can affect the pressure in a water gun. Generally, a larger pump will be able to create higher pressure in the gun. However, the design and efficiency of the pump can also play a role in the pressure it can produce.
  • Mechanical Engineering
