Water heater and area of sunray gatherer
In summary, the water heater needs to collect energy from the sun in order to heat the water up to 40 degrees Celsius. The water heater needs to collect energy for one hour, or 3600 seconds.
Fendergutt
A water heater gathers energy with the help of solar collectors on the roof, where water circulates in pipes and are provided heat from the sunrays that get through a transparent cover. The water is then pumped down in a tank inside the house.
What area must the gatherer have to warm the water in a 200 L (litres) tank from 20 deg. Celsius to 40 deg. Celsius in one hour, if we assume that the system has a coefficient of performance of 20%? (80% of the energy in sunlight is lost, or: ends up other places than the water heater.)
[Answer: 33 m^2]
Given: the intensity of the incoming sunlight is 700 W/m^2 and the specific heat capacity of water is C_water = 4186 J kg^(-1) K^(-1).
Q_water = C_water * m_water * ΔT = 4186 J kg^(-1) * 200 kg * 20 K = 16.7 MJ
I know coefficient of a heat pump given by: η = abs(ΔQ)/ΔW
Right now I'm a little stuck here. Thanks for any help.
You figured the total energy that needs collecting.
You have 1 hour or 3600 seconds.
And you can collect at 20% of 700 w/m2 every second right?
Hi there!
ur on the right track by finding the energy required to raise the temperature of the water by 20 degrees celsius. next remember that the power required to raise the temp of the water is equal to the integral of the intensity of light hitting the solar collectors with respect to the area of the solar collectors. Assuming the intensity of the light over the solar collectors to be constant we can say:
A=P/lIl (the lines on either side of the I represent the modulus)
Power is the energy transferred over the time taken, thus the equation becomes:
A=E/(I*t)
You have already worked out E (the energy required to raise the temp of the water) and the intensity of the light will be 700*0.2 (because only 20% of the light is reaching the solar collectors. Substituting in values:
A=(16.7*10^6)/((700*0.2)*(60*60))
A=33m^2
hope that helps
Thanks a lot for the help, both of you.
Related to Water heater and area of sunray gatherer
1. How does a water heater work?
A water heater works by heating and storing water for use in a household or building. Cold water enters the tank and is heated by a heating element or burner, then the hot water rises to the top of the tank and is delivered to the desired location when a hot water tap is turned on.
2. What is the most efficient type of water heater?
The most efficient type of water heater is a tankless or on-demand water heater. It only heats water as it is needed, rather than constantly heating and storing a large tank of water. This can save energy and money on utility bills.
3. How does a sunray gatherer work?
A sunray gatherer, also known as a solar thermal collector, works by using the sun's energy to heat a fluid, usually water or antifreeze, which is then used to heat a home or building. The collector is usually made of a dark material that absorbs sunlight and transfers the heat to the fluid, which is then pumped through a system to distribute the heat.
4. Can a sunray gatherer be used with a conventional water heater?
Yes, a sunray gatherer can be used in conjunction with a conventional water heater. The sunray gatherer can preheat the water before it enters the water heater, reducing the amount of energy needed to heat the water to the desired temperature.
5. What are the benefits of using a sunray gatherer with a water heater?
Using a sunray gatherer with a water heater can provide several benefits. It can reduce energy costs, as the sun's energy is free and renewable. It can also reduce carbon emissions and be more environmentally friendly. Additionally, it can provide a backup source of hot water in case of a power outage.
  • Mechanical Engineering
  • Materials and Chemical Engineering
26K
