Water manometer to measure change in pressure
In summary, the experiment involves using a water manometer attached to a flask to determine the specific heat of a gas. The two columns of water initially have even levels and the atmospheric pressure is 1.4 x 10^5 Pa. After heating the gas, the water levels change and the change in pressure of the gas in Pa needs to be found. The equations used are P = pgd (gauge pressure) and Pgauge = Pabs - Patm. The attempted solution involves using the formula 1000x9.81x.04 to calculate the pressure, but the correct answer is 392.1Pa, not kPa. Further assistance is requested in finding the error.
BlueSkyy
34
An experiment to determine the specific heat of a gas makes use of a water manometer attached to a flask (the figure below ). Initially the two columns of water are even. Atmospheric pressure is 1.4 x 10^5 Pa. After heating the gas, the water levels change to those shown. Find the change in pressure of the gas in Pa.
https://chip.physics.purdue.edu/protected/GiambattistaMimg/chapter-09/fig-035.gif
well, i took (1000 kg/m3)x(9.81m/s2)x(.04m) and got 392.4 kPa...that's 392400 Pa, right?
but it's not correct...where did i go wrong? i know that it is displaced .02m up and .02m down for a total of .04m, and the density of water is 1000kg/m3 (for this problem)
any help would be appreciated!
1000x9.81x.04 = 392.1Pa., not kPa
I would first commend you on your attempt at solving the problem using the given equations and information. However, it seems that you may have forgotten to take into account the atmospheric pressure in your calculation.
To find the change in pressure of the gas, we need to use the equation Pgauge = Pabs - Patm, where Pabs is the absolute pressure and Patm is the atmospheric pressure. In this case, the given atmospheric pressure is 1.4 x 10^5 Pa. Therefore, the change in pressure of the gas can be calculated as:
Pgauge = (1000 kg/m3)x(9.81m/s2)x(.04m) - (1.4 x 10^5 Pa) = 392.4 kPa - (1.4 x 10^5 Pa) = -1.2 x 10^3 Pa
This means that the pressure of the gas decreased by 1.2 x 10^3 Pa after heating.
In addition, it is important to note that the given figure is in gauge pressure, which means that it is already taking into account the atmospheric pressure. So, you can simply use the given value of 392.4 kPa as the change in pressure of the gas.
I hope this helps clarify your confusion. Keep up the good work in your scientific pursuits!
Related to Water manometer to measure change in pressure
1. What is a water manometer?
A water manometer is a device used to measure changes in pressure. It consists of a U-shaped tube filled with water, with one end connected to the source of pressure and the other end open to the atmosphere.
2. How does a water manometer work?
When pressure is applied to one end of the manometer, the water level in that arm will rise, creating a difference in height between the two arms. This difference in height is directly related to the pressure being applied.
3. What is the advantage of using a water manometer over other types of pressure measuring devices?
A water manometer is a simple and inexpensive tool that is easy to use and provides accurate measurements. It does not require calibration or external power, making it a reliable option for measuring pressure.
4. Can a water manometer measure both positive and negative pressure?
Yes, a water manometer can measure both positive and negative pressure. When pressure is applied to one end, the water level in that arm will rise, and when pressure is applied to the other end, the water level will decrease.
5. What are the limitations of using a water manometer?
One limitation of using a water manometer is that it can only measure pressure differences, not absolute pressure. Additionally, it is not suitable for measuring high pressures or pressures that are constantly changing, as the water level may fluctuate too quickly to accurately read. It also requires a flat and level surface for accurate measurements.
20K
