I Water powered funicular with equal masses?
A paper discusses a modified water-powered funicular system that can operate with equal mass cars, a departure from traditional designs. The physics behind this modification was revised by Uday Raj Khanal, a respected physicist. While the system can start with equal masses, friction will require additional energy input to complete the journey. The authors suggest the funicular could function effectively even with equal loads, though skepticism exists regarding this claim. Overall, the system may improve efficiency but does not achieve perpetual motion.
Suekdccia
TL;DR Summary
I found a paper (https://www.researchgate.net/publication/312123871_Introducing_a_Modified_Water_Powered_Funicular_Technology_and_its_Prospective_In_Nepal) where the authors design a funicular system powered by water but with a modification from traditional systems where apparently the funicular would work even if both "cars" or wagons (the one at the top and the one at the bottom) have the same mass.
Apparently, as the paper says, the physics was revised by Uday Raj Khanal which is a respected physicist in the authors' native country. But even then, could this funicular be built? Could it work?
Sure, I don't see a problem - it just oscillates. In practice though, the cars will be different masses, otherwise there'd be no point to it.
The funicular will start just fine, with equal masses. There's still friction : it won't complete the journey without some energy input. It's just a way of making it faster.
Likes russ_watters
But the authors seem to imply that even with the same mass, the whole route of the funicular could be completed, right?
I didn't give the paper more than a cursory glance, but I seriously doubt anybody who's "respected" would claim that.
The system probably works best if the loads are equal, but it isn't the dreaded "perpetual motion" by any stretch of the imagination : in fact there's a little bit more friction involved because of the longer tracks (mitigated - perhaps completely - by less regeneration involved in ac/decelerating the cars).
Maybe, cut and paste the section you have problems with ?
Likes russ_watters
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
