Water pressure vs. area of an object
In summary, the conversation discusses the relationship between the distance an object is at the bottom of the ocean and its area, specifically in the context of a solid copper ball. The question at hand is how much the diameter of the ball decreases when it is placed at the bottom of the ocean, using the equation P=Po+pgh to solve for the pressure at the bottom. The conversation suggests looking for tables in a textbook about bulk modulus of copper and its alloys to aid in solving the problem.
ebeck1
I've been looking at this question for about 1 hour now, and cannot figure out the relationship between the distance an object is at the bottom of the ocean vs. its area... The question is:
A solid copper ball with a diameter of 3.20 m at sea level is placed at the bottom of the ocean, at a depth of 7.0 km. If the density of the seawater is 1030 kg/m3, how much does the diameter of the ball decrease when it reaches bottom?
I used the equation P=Po+pgh to solve for the pressure at the bottom of the ocean but cannot find a relation of initial pressure and initial are to final pressure and final area...
This problem is obviously about volume elasticity, don't they give you the bulk modulus? look for tables in your textbook about bulk modulus of copper and its alloys.
I can provide some insight into this question. The relationship between water pressure and the area of an object is a fundamental concept in fluid mechanics. When an object is submerged in water, it experiences a force due to the weight of the water above it. This force is directly proportional to the area of the object. This means that the larger the area of the object, the greater the force it experiences from the water pressure.
In your question, the solid copper ball has a larger area compared to a smaller object, such as a sphere with a diameter of 1 meter. This means that the copper ball will experience a greater force from the water pressure at the bottom of the ocean compared to the smaller object. This can be seen in the equation you used, where the pressure (P) is directly proportional to the density of the seawater (p), the acceleration due to gravity (g), and the height (h) of the water column.
Now, as the copper ball descends to the bottom of the ocean, it will experience an increase in pressure due to the increasing height of the water column. This increase in pressure will cause the ball to compress, resulting in a decrease in its diameter. The amount of decrease in diameter can be calculated using the equation for compressibility, which takes into account the initial diameter, the change in pressure, and the bulk modulus of the material (in this case, copper).
In summary, the relationship between water pressure and the area of an object is directly proportional, and this can be seen in the equation you used. As the object descends to the bottom of the ocean, the increase in water pressure will cause it to compress, resulting in a decrease in its diameter. This decrease can be calculated using the equation for compressibility. I hope this helps to clarify the relationship between water pressure and the area of an object in this scenario.
Related to Water pressure vs. area of an object
What is water pressure?
Water pressure is the force exerted by water on a surface or object due to its weight and the depth at which it is submerged.
How does the area of an object affect water pressure?
The larger the area of an object, the more water pressure it will experience. This is because the force of the water is spread out over a larger surface area, resulting in less pressure per unit area.
What is the relationship between water pressure and area of an object?
The relationship between water pressure and area of an object is inverse. As the area of an object increases, the water pressure decreases.
Why is it important to understand the relationship between water pressure and area of an object?
Understanding this relationship is important in various fields such as engineering, architecture, and hydrology. It helps in designing structures that can withstand water pressure and in calculating the force exerted by water on different surfaces.
How can the area of an object be changed to alter water pressure?
The area of an object can be changed by altering its shape or size. For example, a wider and flatter surface will experience less water pressure compared to a narrow and taller surface.
  • General Engineering
  • Mechanics
  • Mechanical Engineering
