Water - Where do you think it came from?
  • B
  • Thread starter Kay Marie
  • Tags
    Water
In summary, water is abundant in the universe and it is possible that it could have helped Earth with life's nutrients.
Kay Marie
Astronomy has been a fascination of mine for many years. As they discuss water on asteroids, I'm curious to see what everyone thinks. Do you feel this gives merit to the panspermia theory?
Astronomy news on Phys.org
That's quite a leap of logic there. Where there's life (as we understand it) there's water but where there's water ?
https://www.space.com/9292-water-ice-common-asteroids-discovery-suggests.html
In this article, in addition to water they also found organic compounds on the asteroids and suggest that it could well have helped the Earth with life's nutrients.
There's also been some discussion on life emerging on planets without water though:
https://io9.gizmodo.com/new-theory-suggests-life-can-emerge-on-planets-without-1660643383
Likes TEFLing
Since hydrogen and oxygen are the first and third most abundant elements in the universe, it should not be surprising that water is ubiquitous. As @jedishrfu said, what does this have to do with panspermia?
Likes TEFLing and stefan r
Indeed. Water is one of the most common molecules in the universe. It's everywhere, floating around is gas and dust clouds.
Likes TEFLing
Hydrogen came from the big bang. The universe cooled enough to form hydrogen atoms after 370,000 years.
Oxygen forms when carbon forms. Carbon, nitrogen, and oxygen cycle through the CNO cycle fusion process. The CNO cycle is the primary path for hydrogen to get burned into helium in large stars. Carbon forms in the triple alpha process. Some oxygen forms from helium burning at the same time the triple alpha process creates carbon. Both become available when stars explode or blow out planetary nebula.
Water forms when interstellar gas clouds cool. In the vacuum of space water transitions directly between vapor and solid. That is not a good environment for life.
All Earth life is associated with water and it is probable that all life everywhere is associated with water. If we find evidence for panspermia it is likely that the sperm(seed)/cyst/spore need water in order to become active. There is no need for the source of water to be the same as the source of the spores. A cyst can be embedded inside of a dry rocky chunk of asteroid. A foamy silica substance is more likely to enter an atmosphere with live samples. A icy snowball will melt/evaporate on reentry and tends to explode. Ideally you would want a heat shield like Apollo capsules or the space shuttle but it can be done with 99+% of the mass burning away. It does not need to be an efficient reentry vehicle. It could come in with millions of cysts. Only one needs to survive.
Likes TEFLing
CH4, NH3, OH2 are amongst the most common molecules in the universe
FAQ: Water - Where do you think it came from?
Where did water originally come from?
The most widely accepted theory is that water on Earth came from comets and asteroids that collided with the planet during its formation. These icy bodies contained water molecules that were released upon impact and eventually accumulated on Earth's surface.
How did water end up on Earth?
As the Earth's surface cooled and solidified, water vapor from volcanic eruptions condensed and formed oceans. Over time, more water was brought to the planet by comets and asteroids, as well as through internal geological processes.
Is all water on Earth the same age?
No, some water on Earth is much older than others. The water that came from comets and asteroids is considered to be the oldest, dating back to the formation of the solar system. However, water that is constantly recycled through the Earth's hydrological cycle can be considered "younger" in comparison.
Can water be found on other planets?
Yes, water has been discovered on other planets and moons in our solar system, such as Mars, Europa, and Enceladus. It is also believed that water exists on other planets outside of our solar system.
How much of Earth's water is accessible for human use?
Only about 1% of Earth's water is fresh and accessible for human use, with the majority of it being stored in glaciers and ice caps. The rest is either salty ocean water or inaccessible groundwater. This highlights the importance of conserving and managing our limited freshwater resources.
