Wave equation of string under tension with a mass at x(a)
In summary, the wave equation of a string under tension with a mass at x(a) is a mathematical equation that describes the motion of a string under tension with a mass attached at a specific point. It is derived from classical mechanics and wave mechanics and makes certain assumptions such as uniformity, perfect tension, and inelasticity. It has many practical applications and can be extended to other systems.
Dustinsfl
2,281
We have a string of length \(\ell\) with fixed end points. At \(x(a)\), we have a mass. We can break the string up into two sections \(a + b = \ell\); that is, a is the distance up to the mass and b afterwards. The string is under tension \(T\).
My question is why is the DE then
m\ddot{x} + \Big(\frac{1}{a}+\frac{1}{b}\Big)Tx = 0
Shouldn't this work out to be the wave equations?
Can someone explain where \(\big(\frac{1}{a}+\frac{1}{b}\big)\) this piece comes from?
  • Screenshot from 2014-09-24 16:39:49.png
Mathematics news on Phys.org
The equation \[
is not the wave equation, but rather the equation of motion for the mass on the string. This equation is derived from Newton's second law, which states that the sum of the forces acting on an object is equal to its mass times its acceleration.
In this case, the mass is subject to two forces: the tension in the string and the force of gravity. The tension in the string is given by the equation \(\frac{T}{a}x(a)+\frac{T}{b}x(b)\), which is the sum of the forces acting on the mass at points \(a\) and \(b\). This is divided by the mass \(m\) to get the acceleration term \(\Big(\frac{1}{a}+\frac{1}{b}\Big)Tx\).
To understand where the term \(\big(\frac{1}{a}+\frac{1}{b}\big)\) comes from, we can think about the physical interpretation of this equation. The term \(\frac{1}{a}\) represents the acceleration of the mass due to the tension at point \(a\), and \(\frac{1}{b}\) represents the acceleration due to the tension at point \(b\). Adding these two terms together gives the total acceleration of the mass on the string.
In summary, the equation \[
is derived from Newton's second law and represents the equation of motion for the mass on the string, not the wave equation. The term \(\big(\frac{1}{a}+\frac{1}{b}\big)\) represents the total acceleration of the mass due to the tension at points \(a\) and \(b\).
FAQ: Wave equation of string under tension with a mass at x(a)
What is the wave equation of a string under tension with a mass at x(a)?
The wave equation of a string under tension with a mass at x(a) is a mathematical equation that describes the motion of a string that is stretched under tension and has a mass attached at a specific point. It is represented as a partial differential equation and is used to study the behavior of waves on a string.
How is the wave equation of a string under tension with a mass at x(a) derived?
The wave equation of a string under tension with a mass at x(a) is derived from the principles of classical mechanics and wave mechanics. It takes into account the tension, mass, and displacement of the string, as well as the forces acting on it, to create a mathematical model for its motion.
What are the assumptions made in the wave equation of a string under tension with a mass at x(a)?
The wave equation of a string under tension with a mass at x(a) makes certain assumptions, such as the string being uniform and under perfect tension, the mass being small compared to the string's length, and the string being inelastic. These assumptions simplify the equation and make it easier to solve.
How is the wave equation of a string under tension with a mass at x(a) used in real-world applications?
The wave equation of a string under tension with a mass at x(a) has many practical applications, such as in musical instruments, engineering design, and seismology. It helps to understand the behavior of waves on strings and how they can be manipulated for different purposes.
Can the wave equation of a string under tension with a mass at x(a) be extended to other systems?
Yes, the wave equation of a string under tension with a mass at x(a) can be extended to other systems, such as elastic rods, membranes, and even electromagnetic fields. It is a fundamental equation that can be adapted and applied to various physical phenomena.
