Wave equation, psi with dots and things like that....
In summary, the Schrodinger equation is very hard to understand, but it can be represented using a sine wave function, a cosine wave function, and a psi function with two dots. The chain rule can be used to understand how the derivative of these functions is different.
Joao
80
Hi everyone! I'm a psychologist form Brazil, so sorry for the bad English and for the lack of knowledge in math!
I ve been trying to understand the Schrodinger equation and, as predicted, it's very hard!
Please, help me with this:
A sine wave function can be written as:
F (x) = sin (x)
And that can be represented as psi.
The the derivative of that function can be written as:
F (x) = cos (x)
And that can be represented as psi dot.
Also, the derivative of psi dot can be written as:
F (x) = - sin (x)
And that's psi with two dots.
So far I understood!
But things get confusing here:
A wave equation can be written as:
F (x) = A sin (2π f x )
Where A stands for the amplitude, 2π f x stands for the period.
But, in this video:
It is stated, at 8 mins, that the correct wave function is, as expected:
F (x)= sin (2π f t)
And that's represented by psi
But the derivative of that is
F (x) = 2π f cos (2π f t)
And not
F (x) = cos (2π f t)
(And that's represented by psi dot)
To make things worst, the derivative of that last equation, psi dot, is represented by
## f (x) = - (2π f)^2 sin (2π f t) ##
And not just
F (x) = - sin (2π f t)
(And that's represented by psi with 2 dots)
Why is that?
Thanks a lot!
@Joao you need a calculus course.
Dots above a function normally denote a time derivative. The normal convention for a derivative is either ##f'## or ##\frac{df}{dx}##.
Then, of course, you have "partial" derivatives ##\frac{\partial \psi}{\partial x}## and ##\frac{\partial \psi}{\partial t}## etc.
In answer to your question, there is a little thing called the chain rule, which is quite important!
Likes Joao
Thanks a lot! I will do that! So, that makes sense, the derivative of
Ψ = Sin (2πft)
Is
Ψ(dot) = 2πf cos (2πft)
And not
Ψ(dot) = cos (2πft)
And after I make the calculus course, I will understand why?
Really sorry to bother!
Ψ = Sin (2πft)
Is
And not
Ψ(dot) = cos (2πft)
Yes. You could, say, draw a graph of ##\sin(2x)## and look at the slope. You'll see that it is steeper than the graph of ##\sin(x)##.
In fact, it's twice as steep at each point ##x##.
Which is what you get from the chain rule.
Likes Joao
Thanks a lot for your time! I'll do the calculus course! =)))))
Happy 2018!
Related to Wave equation, psi with dots and things like that....
1. What is the wave equation?
The wave equation is a mathematical equation that describes the behavior of waves. It is a second-order partial differential equation that relates the second derivative of a wavefunction (psi) to its spatial and temporal derivatives.
2. What are the dots in the psi equation?
The dots in the psi equation represent the time derivative of the wavefunction. This is important because it helps us understand how the wavefunction changes over time.
3. What do the variables in the wave equation represent?
The variables in the wave equation represent different physical properties of a wave. For example, the spatial derivative represents how the wave changes in space, while the temporal derivative represents how the wave changes over time.
4. How is the wave equation used in science?
The wave equation is used in many areas of science, including physics, engineering, and acoustics. It is used to model and predict the behavior of various types of waves, such as sound waves, electromagnetic waves, and water waves.
5. Is the wave equation a fundamental law in physics?
Yes, the wave equation is considered a fundamental law in physics because it describes the behavior of waves in a variety of contexts and is used to derive other important equations, such as the Schrodinger equation in quantum mechanics.
  • Differential Equations
