Wave equation with a slight alteration
X(z) is X(z) = A\sum_{n=0}^\infty z^{n+1} = A\frac{z^2}{z-1} = \frac{A}{1-z} - A.In summary, the conversation discusses solving a differential equation with a non-constant coefficient and a boundary condition. It is for a rope subjected to a body force and small lateral oscillations. The problem can be simplified by assuming a harmonic time dependence and using separation of variables. The solution is found to be a series with a specific recurrence relation and initial conditions or boundary conditions are needed for a unique solution. The conversation also mentions Frobenius's Method and provides a
etotheipi
I want to find the particular solution to the differential equation$$g(L-x) \frac{\partial^2 y}{\partial x^2} = \frac{\partial^2 y}{\partial t^2}$$with the boundary condition ##y(0) = 0## for all ##t##. If the coefficient of ##\frac{\partial^2 y}{\partial x^2}## were constant then it could be solved with ##y=A\sin{(kx -\omega t)}##, but how could I go about solving it in this case? Thanks
Likes Delta2
Is ##g## a constant or a function? If I assume it is a constant, then this wave equation is applicable for an inhomogeneous media with a resonance at ##x=L##. What is the domain for this problem? Is it ##0\leq x## or is there another boundary? If there is no other boundary I'm assuming a radiation condition must apply. Also, what is the context of this problem? Finally, I see that this is listed as a "basic" thread, but in reality this problem is most suitable for advanced undergraduate or graduate students.
If you have learned about classification of partial differential equations, then you should notice that the variable coefficient changes sign at ##x=L## so the nature of the partial differential equation changes from hyperbolic for ##x<L## to elliptic for ##x>L## and therefore characteristics won't get you the solution you want.
Given that, I would either use separation of variables or simply assume harmonic time dependence. Either way you will get an ordinary differential equation with variable coefficients for the spatial variation of the solution. The solutions have different character on either side of the resonance (also called a turning point in this context) and you will need to match them. I expect there will be some subtleties here; the singularity will casue problems that are usually dealt with by adding a small amount of damping to the problem (which is partially why I asked about the context).
That should get you started, but again, this is not a basic problem.
jason
Likes Delta2 and etotheipi
Thanks for the reply! Here ##g## is just a constant, the gravitational field strength. Sorry I didn't specify! The domain is ##0\leq x \leq L## and there is no boundary condition on ##y(L)##. The context is a rope (fixed at one end) subjected to a body force of force density ##\rho \vec{g}##, with ##\vec{g}## constant, and subjected to small lateral oscillations. It is expected that various harmonics will be displayed.
I will have a look at your suggestions, specifically I'll try separating variables. I have essentially no prior background for methods to solve PDEs other than guessing, though, so I might need to go and read up about some theory beforehand!
How about this; the first harmonic at least looks like it could be solved with a function like$$y(x,t) = A(x)\sin{(\omega t)}$$We would have ##\frac{\partial ^2 y}{\partial t^2} = -\omega^2 A(x) \sin{(\omega t)}## and also ##\frac{\partial ^2 y}{\partial x^2} = A''(x) \sin{(\omega t)}##. That results in an ODE $$\omega^2 A(x) + g(L-x) A''(x) = 0$$
The restricted domain makes this a much easier problem than what I had assumed based on your original post. You are on the right track - now you need to solve this ODE. Have you learned about series solutions of ODEs?
jason
Likes etotheipi
I can't remember exactly how to do this, but I'll try and refresh and will post however far I get up to!
I get these recurrence relations from inserting ##A(x) = \sum_{n=0}^{\infty} a_n x^n##:$$\omega^2 a_{n-1} + n(n+1)gLa_{n+1} -n(n-1)ga_n = 0$$ $$\omega^2 a_0 + 2gLa_2 = 0$$So I guess I just need to solve the recurrence relation... also ##a_0 = 0## because of the boundary conditions which means that ##a_2 = 0## also.
I won't check your algebra but it looks like you are on the right track.
By the way, for a unique solution you will need to specify initial conditions, as well as a boundary condition at ##x=L##. For example, for a freely swinging end ##\partial y(x=L,t)/\partial x = 0## is probably a reasonable choice. Your added boundary condition at ##x=L## will probably yield a set of discrete choices for ##\omega##, and it may require a summation of different modes to satisfy the initial conditions. This means that you would essentially be following the standard separation of variables technique (and you might need both cosine and sine terms). If you aren't familiar with the math a good free reference is
http://www.physics.miami.edu/~nearing/mathmethods/
If you just want to see what the different modes look like, then initial conditions might not be needed and you won't form a series to satisfy the initial conditions, but you will still need the extra boundary condition.
jason
Likes etotheipi
There are certainly separable solutions of the form [itex]y(x,t)=X(x)\mathrm{e}^{\mathrm{i}\omega t}[/itex], where [itex]X[/itex] satisfies [tex]
g(L - x)X'' + \omega^2 X = 0.[/tex] Now the substitution [itex]x=L(1−z)[/itex] yields [tex]
z\frac{d^2X}{dz^2} + \lambda X = 0[/tex] where [itex]\lambda = (\omega^2L)/g[/itex].
Now that the singular point is at the origin, we can use Frobenius's Method directly: Seek a series of the form [itex]X(z)=\sum_{n=0}^\infty a_nz^{n+r}[/itex] where [itex]a_0 \neq 0[/itex]. This gives [tex]
a_0 r(r-1) + \sum_{n=0}^\infty \left(a_{n+1}(n + r + 1)(n + r) + \lambda a_n\right)z^{n+r} = 0[/tex] and taking [itex]r=1[/itex] yields the recurrence [tex]
a_{n + 1} = \frac{-\lambda}{(n+1)(n+2)}a_n[/tex] with solution [tex]
X(z) = a_0\sum_{n=0}^\infty \frac{(-1)^n (n+1)}{((n+1)!)^2}\lambda^n z^{n+1}.[/tex]
The linearly independent solution will have the form [tex]
CX(z) \ln z + \sum_{n=0}^\infty b_n z^n[/tex] (see https://en.wikipedia.org/wiki/Frobenius_method#Roots_separated_by_an_integer). In this case this solution is also nicely behaved at the origin as [itex]z^n \ln z \to 0[/itex].
For the special case [itex]\lambda = 0[/itex] we have of course [itex]X(z) = Az + B[/itex].
Likes etotheipi
Thanks @pasmith! I hadn't heard of Frobenius's method before so it was interesting to see how you handled the step with the recurrence relation. I will need to do some more reading around this area to get a little more confident with this!
pasmith said:
[tex]
If we set [itex]a_0 = A\lambda[/itex] then we can write this as [tex]
X(z) = AF(\lambda z)[/tex] where
[tex]
F(z) = \sum_{n=0}^\infty \frac{(-1)^n}{n!(n+1)!} z^{n+1}[/tex] satisfies [tex]
zF'' + F = 0.[/tex] This tells us that the eigenvalues [itex]\lambda[/itex] are, depending on the boundary condition at [itex]x = 0[/itex] ([itex]z = 1[/itex]), either zeroes of [itex]F[/itex] or zeroes of [itex]F'[/itex]. At [itex]x = L[/itex] ([itex]z = 0[/itex]) we have [itex]F(0) = 0[/itex] and [itex]F'(0) = 1[/itex].
Note, however, that the derivative of [itex]z \ln z[/itex] does not exist at the origin and blows up as [itex]z \to 0^{+}[/itex], which suggets that you won't need it.
Likes etotheipi
Related to Wave equation with a slight alteration
1. What is the wave equation with a slight alteration?
The wave equation with a slight alteration is a mathematical model that describes the behavior of waves in a medium. It is similar to the standard wave equation, but with a small modification to account for more complex wave behavior.
2. How does the slight alteration affect the wave equation?
The slight alteration in the wave equation introduces a new term that accounts for the nonlinearity of the wave behavior. This means that the wave equation can now accurately describe more complex waves, such as shock waves or solitons.
3. What are some real-world applications of the wave equation with a slight alteration?
The wave equation with a slight alteration has many practical applications, including predicting the behavior of sound waves in air, ocean waves, and electromagnetic waves. It is also used in fields such as acoustics, optics, and seismology.
4. How is the wave equation with a slight alteration derived?
The wave equation with a slight alteration is derived from the standard wave equation using mathematical techniques such as perturbation theory. This allows for the inclusion of the nonlinear term, which is typically a small correction to the original equation.
5. What are some limitations of the wave equation with a slight alteration?
While the wave equation with a slight alteration is more accurate than the standard wave equation, it still has some limitations. It does not account for factors such as dispersion, dissipation, or wave interactions, which may be important in certain situations. Additionally, it is only applicable to linear media, meaning that the properties of the medium do not change with the amplitude of the wave.
  • Differential Equations
