I Wave function using the time dependent Schrodinger equation
ThiagoSantos
Given a wavefunction ψ(x, 0) of a free particle at initial time t=0, I need to write the general expression of the function at time t. I used a Fourier transform of ψ(x, t) in terms of ψ(p, t), but, i don't understand how to use green's functions and the time dependent schrodinger equation to get my answer. What's the relationtship between them?
The time-dependent Schrödinger equation reads
$$\mathrm{i} \hbar \partial_t \psi(x,t)=\hat{H} \psi(x,t).$$
Let's assume for simplicity that
$$\hat{H}=\frac{\hat{p}^2}{2m} + V(\hat{x}),$$
i.e., that ##\hat{H}## is not explicitly time dependent. Then the formal solution of the equation above is
$$\psi(x,t)=\exp \left (-\frac{\mathrm{i} \hat{H} t}{\hbar} \right) \psi(x,0).$$
This you can write in the form
$$\psi(x,t)=\int_{\mathbb{R}} \mathrm{d} x' \left \langle x \left |\exp \left (-\frac{\mathrm{i} \hat{H} t}{\hbar} \right) \right| x' \right \rangle \psi(x',0)= \int_{\mathbb{R}} \mathrm{d} x' G(x,x',t) \psi(x',0),$$
i.e., the propator is
$$G(x,x',t)=\left \langle x \left |\exp \left (-\frac{\mathrm{i} \hat{H} t}{\hbar} \right) \right| x' \right \rangle.$$
Usually it's of course difficult to really calculate the propagator.
For a free particle, where ##\hat{H}=\hat{p}^2/(2m)## you can use the momentum eigenstates to evaluate it:
$$G(x,x',t)=\int_{\mathbb{R}} \mathrm{d} p \langle x |\exp[-\mathrm{i} \hat{p}^2 t/(2m \hbar)]|p \rangle \langle p|x' \rangle.$$
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
