Wave function -- Why is there an imaginary part?
In summary, the complex (imaginary) part of a wave function is necessary in order to accurately model the continuous transformations between quantum states. This concept is not exclusive to quantum mechanics, as classical mechanics can also be described using complex wave functions. While these numbers may not have a physical meaning, they are just as "real" as other mathematical concepts, such as negative numbers.
preitiey
If wave is a real concept, then why we have a complex(imaginary) part associated with the wave function?
It is the squared modulus of the wave function (= a probability distribution) that is of physical interest, since it predicts the likelihood that physical observables assume certain values. The wave function itself cannot be measured and, as far as I know, does not have a physical meaning.
Ordinary waves are modeled as complex numbers too though. It's not a quantum-only thing. https://en.wikipedia.org/wiki/Phasor
An imaginary number is not imaginary. That's just a word someone dreamt up one day! Complex numbers are just as "real" as vectors, matrices and continuous functions.
Likes entropy1 and bhobba
Technically its got to do with the requirement for continuous transformations between quantum states. If a system is in a state and one second later is in another state then we reasonably expect that after half a second it went through some state in getting there. It turns out if you require that then so called imaginary numbers are required:
http://www.scottaaronson.com/democritus/lec9.html
BTW they are no more or less imaginary than say negative numbers. You can't point to a negative number of ducks for example. But if you owe someone two ducks then saying you have -2 ducks is very convenient. Same with imaginary numbers. You can't point to square root -1 (doubly so since you can't even point to -1 of anything) but in modelling some things its very convenient to introduce it - QM being a good example.
Thanks
Bill
Likes entropy1 and Heinera
Classical mechanics can also be described in terms of complex wave functions, so they aren't inherently quantum mechanical things.
Related to Wave function -- Why is there an imaginary part?
1. What is the wave function and why does it have an imaginary part?
The wave function is a mathematical description of the quantum state of a system, and it is used to predict the behavior of particles on a microscopic level. The imaginary part of the wave function is necessary to fully describe the state of a particle, as it represents the particle's phase or rotation in space.
2. Can the wave function be physically observed or measured?
No, the wave function is a mathematical construct and cannot be directly observed or measured. However, the effects of the wave function can be observed through experiments and measurements.
3. What is the significance of the imaginary part of the wave function?
The imaginary part of the wave function is crucial in understanding the quantum behavior of particles. It allows for the interference of multiple wave functions, which is a key aspect of quantum mechanics.
4. Does the imaginary part of the wave function have any physical meaning?
No, the imaginary part of the wave function does not have a physical meaning. It is simply a mathematical tool used in quantum mechanics to accurately describe the behavior of particles.
5. Can the imaginary part of the wave function be negative?
Yes, the imaginary part of the wave function can be negative. The imaginary part is a complex number, which can have a positive or negative value. The sign of the imaginary part does not affect the physical behavior of the particle, as it is only used in mathematical calculations.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
