Wave Function_vibtrating nuclei
In summary, the ground state wave function governing the motion of a pair of vibrating nuclei looks like: - a = alpha = mu*w/(h bar), which is determined by mu = reduced mass of the pair- where w = angular vibrational frequency- root mean square = <x2> - <x>2- where <x2> = integral (-infinite to infinite) wave(x) x2 wave(x) dx- <x> = integral (x=o to L) p(x) x p(x) dx which I got as 0 in the end- so...I input:- root mean square = <x2> - <x>
terp.asessed
127
The Ground state wave function governing the motion of a pair of vibrating nuclei looks like:
wave function = wave (x) = (a/pi)1/4 e-ax2/2
where a = alpha = mu*w/(h bar), which is determined by mu = reduced mass of the pair
...So, suppose the vibrating atoms in question were C and O. Compute what v~, the frequency of the vibration in cm-1, would have to be if the root-mean square fluctation in bond length were 0.035Angstom.
I lost track of the units for my solution, and I am not sure if I have done correctly...
= which I got 1/(2a) as a result
so...I input:
root mean square = <x2> - <x>2 = 1/(2a) - 0 = 1/(2a)
since
root mean square = 0.035 angstrom = 1/(2a) and b/c a = mu*w/(h bar), I rearranged so that:
w = (h bar)/(0.07mu)...where mu = m1m2/(m1 + m2)
For mass of 1 C atom: 12.01g/(6.022x1023 atoms) x 1kg/103g = 1.99 x 10-26kg
For mass of 1 O atom: 16.00g/(6.022x1023 atoms) x 1kg/103g = 2.66 x 10-26kg
mu = 1.14 x 10-20kg
therefore w = (h/(2pi))1/(0.07mu) = 1.32 x 10-13 omega (is this right?) I know h has units of J*2 and mu = kg...but together they do NOT make omega...
therefore v~ = w/(2pi*c) where c = speed of light = 1.32 x 10-13 (assuming the unit is correct) / (2pi*3x108m/s) = 7.02 x 10-23 s-1
b/c I got lost track of units...I am not sure if the units in the solution is right...if someone could (1) explain the units in each calculations I did and then (2) give me hints as how to keep track of units for near future too, that would be so wonderful.
You made a numerical error in your value of [itex]\mu[/itex]. If your mass for a carbon atom is ~10-26kg and your mass for an oxygen atom is ~10-26kg, there's no way the reduced mass will be ~10-20kg. Fix that first. As for the units, Planck's constant [itex]\hbar[/itex] is in J s (joule-seconds). Maybe breaking this (and everything else) down into base units (kg, m, s) will help. Just a heads up, you also forgot the "root" part of "root mean square."
Hello--thanks you for the reply--so, you're right, I miscalculated: μ = 1.14 x 10-26 kg
Also, since,
ℏ = J*s = kg*m2/s2...is omega a right unit for w?
w = (h/(2pi))1/(0.07mu) = 1.32 x 10-7 (J*s)/kg = 1.32 x 10-7 m2/s...? Did I make mistake? It is of acceleration unit, not velocity...
Aside, could you please clarify by what you mean by "root part of the root mean square"? If you could, thanks!
You're close with [itex]\hbar[/itex]. Joules are kg*m2/s2 (you can remember this by recalling that joules are a measure of energy and kinetic energy is [itex]\frac{1}{2}mv^2[/itex]), so J*s is kg*m2/s. Also, it's clear that you know that [itex]\mu[/itex] has units of kg, but 0.07 also has units. This comes from the root mean square of distance, which, by the way, is [tex]\sqrt{\langle x^2 \rangle - \langle x \rangle ^2 }[/tex] not just [tex]\langle x^2 \rangle - \langle x \rangle ^2 [/tex] The units of rms distance are the same as the units of plain old distance, which in this case is just angstroms. Hopefully that should get you started.
First of all, great job on attempting to solve this problem! It seems like you have the right approach, but you got a little mixed up with the units.
To clarify, the units for the wave function are not important in this problem. The only important units are for the root mean square fluctuation in bond length, which is given in angstroms.
To keep track of units, it can be helpful to write out the units for each variable in the equation. For example, in this case, the units for the reduced mass (mu) would be kg, the units for the angular vibrational frequency (w) would be s^-1, and so on.
Now, let's go through your calculations step by step to see where the units got mixed up.
1. For the root mean square fluctuation in bond length, you correctly calculated it as 1/(2a) using the equation you provided. However, the units should be in angstroms, not 1/m. So your final answer should be 0.035 angstroms.
2. For the reduced mass (mu), you correctly calculated it as 1.14 x 10^-20 kg. However, when you calculated the mass of the C and O atoms, you used the wrong conversion factor. The correct conversion factor to use would be 1 amu = 1.66 x 10^-27 kg. So the mass of 1 C atom would be 12.01 amu, which is equal to 1.99 x 10^-26 kg. Similarly, the mass of 1 O atom would be 16.00 amu, which is equal to 2.66 x 10^-26 kg. Using these values, you should get a reduced mass of 1.14 x 10^-26 kg, not 1.14 x 10^-20 kg.
3. For the angular vibrational frequency (w), you correctly calculated it as (h bar)/(0.07mu). However, you used the wrong units for h bar. The correct units for h bar are J*s, not J*2. So your final answer for w should be in units of s^-1.
4. Finally, for the frequency (v~), you correctly used the equation v~ = w/(2pi*c). However, you used the wrong units for c. The speed of light (c) is in units of
Related to Wave Function_vibtrating nuclei
1. What is a wave function for vibrating nuclei?
A wave function for vibrating nuclei is a mathematical representation of the probability of finding a nucleus in a certain state of vibration. It describes the spatial distribution and energy of the vibrating nucleus.
2. How is the wave function of a vibrating nucleus calculated?
The wave function of a vibrating nucleus is calculated using quantum mechanics and the Schrödinger equation. This equation takes into account the mass, charge, and potential energy of the nucleus to determine the probability of finding it in a particular state of vibration.
3. What is the significance of the wave function for vibrating nuclei?
The wave function for vibrating nuclei is significant because it allows us to understand and predict the behavior of nuclei at the quantum level. It also helps us to study the properties of nuclear vibrations and their effects on nuclear structure and reactions.
4. Can the wave function for vibrating nuclei be experimentally measured?
No, the wave function for vibrating nuclei cannot be directly measured. However, the predictions of the wave function can be tested through experiments such as scattering experiments and nuclear reactions.
5. How does the wave function for vibrating nuclei differ from other wave functions?
The wave function for vibrating nuclei differs from other wave functions in that it specifically describes the behavior of a vibrating nucleus. Other wave functions describe different quantum systems, such as electrons in an atom or particles in a box.
